Gtr & Stance Special-Cc02
OTR
Hi Guys,
We have the following on SPECIAL, this is wheels and tyres fitted, balanced and packed ready for delivery.
Package 1.
CC02 18x9.5+15 Matt Black, Matt Bronze and Gloss Bronze
CC02 18x9.5+20 Matt Gunmetal
Tyres: Achilles 123S Track 265/35/18
Price: $1900
Package 2.
Above Wheels
Tyres: Achilles 123S Track 235/40/18
Price: $1800
Package 3.
Above wheels
Tyres: Hankook RS3 285/35/18
Price: $2100
Delivery anywhere Metro $100 (WA-$150, NT-$200)
  • 8 months later...
    • Maybe I used the wrong sandwich plate as well. Used one piece instead of two piece.
