V36 Rev Probs, Firmware Update Anyone?
Yeah, that doesn't necessarily mean that it flows. If the exit side pipework is blocked somewhere (in the hose, in the nipple that it returns into the motor/plumbing, etc), but the supply side is not blocked, then when you crack the bleeder you will get flow from the open side. But when you close the bleeder - no flow. And.... therefore no heat. You might have to work a little harder to prove it to yourself. When I bought my engine the entire IACV bleeder was choked with cooling system schmutz. I had to clean it and the pipework out before it would work.
"The outer is separated from the inner by the rubber" duh....I know that, I should have figured that out, gheeze. thanks, I'll replace it.
Hey Yeah ill be there ! Hussling hard now to get seat time and make car all good see if can get some early track time over east 🤞 Itd be really nice to have some luck 😁
The two tyres U have mentioned are the same height as the profile height is a calculated percentage of the width
appears to be, I loosened the bleeder on top IACV and coolant came out.
