Stagea M35 Reversing Bulb Replacement
miekaspop
Hoping that it’s as simple as it looks. I have removed the interior liner from the tailgate of my M35 and found where I suspect the reverse globes is situated. However, on removal of the rubber grommet I’m unsure of the correct way to get the bulb housing out as it can’t be seen. Do not want to be forcing anything.....Need little fingers and hands like Japanese, so as I can feel what is really happening inside that cut out. Thank you in advance for any one that could help or advise how they have done it.
I've never done it & the exploded drawing (attached) doesn't give many clues, but hopefully somewhat helpful.
When you work it out maybe you can post some tips ....
I believe that you need to remove the bolts holding the lamps in place and remove the entire unit in one go before getting access to the actual globe. I also got as far as removing the trim and saw the exposed bolts but wasnt game to try and threw it all back together instead. Havent tried since. =)
I did this a few weeks ago.. It's a mater if removing boot door trim by unscrewing all the plastic trim screws all the way around and removing the little handle pocket to pull the boot closed fist. Then this will expose the fiberglass underneath where all the reverse lights and electrics are mounted to ... On each side you will see three bolts 10mm from memory you need a long socket to get to the but once removed the reverse light assembly just pupils out and you can the remove the bulb... A pain in the arse Rey to to replace the bulb so for futur hassle free bulb replace ment I cut out a hole from the in side of the Fiberglass covering to access the bulb? so now it's just a matter of removing interior boot for trim and removing buld replace and re assemble trim 10 mins no longer once the holes are cut
I tried searching online to find an LED bulb equivalent to replace the ordinary bulb. I looked at the previous thread and that diagram it shows 26550 for the bulb, which I guess is Nissan only. Has anyone replace their bulbs with LED's. Does the 7440 T25 fit?
  • 6 months later...
Final replaced the globes with T10 7.5W High Power Lens Cree Q5 Car Reverse LED Light as Lakes101 instructions.
Here a a few photos as example....Dont forget you need a 10mm long socket and remember to try the led lights are working and the right way around before reassembling everything.
Edited by Old Fella
Nice little how-to; are the cree globes super bright?
Super Bright...These little things are like a lighthouse searching the sky.
tn_gallery_133305_5631_11910.jpg I would suggest not buying this type as the light is a straight beam and does not throw back to the reflector
tn_gallery_133305_5631_31305.jpg This is type that you need. Once done, you wont be sorry the time that it takes.The end result are worth it
Edited by Old Fella
    • New R34 owned here (from the US) and found a gem, '98 GTT with ~6k miles, super clean & completely stock. When shifting there's no grinding, shifts smooth, etc. The concern I have are 2 things: 1) Only in 2nd and 3rd... when maintaining a slower speed (in traffic as an example) as I let off/on the gas, the shifter will slightly move and vibrate. If the clutch is engaged, none of this happens. It's not bad, but enough to feel like something isn't necessarily right. 2) This mainly happen in 4th or 5th... the shifter slightly bounces up and down, almost like it's riding on unbalanced tires (and I do think the tires are unbalanced as I get a little of that bounce feel at higher speeds, which is maybe why it only happens in 4th/5th). Lastly, and sorry for this noob question but I want to work on this car myself, can someone teach me some on these manual transmissions? Like servicing them, best products to use, etc.; would be greatly appreciated. Thanks!!
    • Coilovers aren't even the first step. Bushes, subframe position and alignment, HICAS elimination, adjustable upper arms and traction arms in order to dial out understeer. All these things need/deserve attention first. ARBs (There's no such thing as a swaybar. Please, everybody, stop calling them that) are useful if you want to limit spring stiffness. Otherwise you can control body roll with springs. Spring and damper rates are a function of road surface, speed and usage. There is no solution that works for all cases.
    • Define "nothing". Is the starter spinning but not the engine? Engine turning but not firing? If the engine is turning but not firing, then you are missing either fuel or spark. You need to find whichever has gone missing.
    • Shitbox Tiguan updates, got the APR OTS tune put back on (no charge for it to be removed/added back), didn't want to just come in just for that (not a fan of wasting people's time for nothing) so I purchased an APR dog bone insert. The boys at German Performance Garage said they would fit it for free too since they had 1x hoist free. Now that's service you don't normally get from most workshops. Anyhow, tune back on, snow grate pulled out, dog bone insert back in and not going to lie, a few smiles when I nailed it around the industrial area heading back onto the M7. Amayama also said 1 to 2.5 month wait for the RB25DE heater hose, yeah why not, car has been off the road for nearly 3, what's a other 2.5?
    • Hmm I'm going to approach this from the other side... What is the car doing that you don't like or what would you like the car to do that is currently isn't doing (handling wise that is)
