Rb26 Head Rear Oil Drain
lol... I suggest you take your car somewhere else mate if that kind of advice is being given out.
There is PLENTY of info in the oil control thread. Users like r33_racer and similar have posted some pretty detailed information on the topic with full designs that are tried/proven after days on racetracks.
You would actually find that a breathing system is more important on a engine that runs E85. The fumes from E85 actually contain moisture and if your breathing systems isn't correctly set up it will mix with the oil. I don't run a drain from the back of my head but ive got a line going from the rear turbo drain back up too my catch can equalizing the crank case pressure.
  • 11 months later...
instead of starting a new thread, i thought i would ask here
which head drain kit has the shallowest profile
i know they may not be needed but for a few hundred bucks, it not like a massive investment either way
for a rb2630 if that makes any difference
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
