New R32 Owner From Nz!
Jazzadub
Hey all,
I have recently upgraded from a B18CR integra to a 330wkw R33 sedan with an RB26DETT drivetrain conversion.
Unfortunately in my 2nd day of ownership a high boost pull combined with wheelspin destroyed the oil pump and the car lost oil pressure!
Quickly turned the engine off, and there was nothing foreign in the oil, so I think I have saved the engine from serious damage!
A crank collar and N1 oil pump had recently been installed, as the original one had cracked due to the small engagement.
It seems as though even that was not strong enough!
I am now in the process of saving up until I can take the car to RIPS and get the repairs done.
My research shows me that I will not be let down by them, and I would rather spend more money to get it done right, than have to do this all again a second time!
Basically I am looking to get the following work done, so that I will be able to use the power without risking breakages, and also be able to take it to the track on occassion!
Tomei oil pump
Enlarged capacity/baffled oil sump
New main & rod bearings
Balanced rods
Piston rings
Replace worn oil/water lines
1.5mm oil restrictor
Head gasket
Head studs
Timing belt
Water pump
Tensioner
Catch can setup
Adjustable cam gears
Retune
Oil pressure switch
Based on the hours and hours of reading I've done, I believe that the above will go a long way to making this a reliable RB26! It should have more potential for power, and the mods will give me peace of mind that my oil pressure isn't up the piss while I'm beating on it around the track!
The current mods to the RB26 are a pair of Garrett GT2860-9s, 770cc injectors, and a Link G4 ECU.
It would be good to know what people think this combination should be capable of putting out once the above modifications have been done!
Anyway, glad to be a member and all your comments, thoughts, and recommendations are greatly appreciated!
Edited by Jazzadub
Thanks man!
You probably have an RB26 in your 32 I suppose?
Do you have any experience with rectifying the oil system failings? Does my list look like it should cover everything off?
Thanks man!
im now running an rb30.
there is a massive topic in the forced induction thread regarding oil control for rbs.
have a good read(I think 60 pages from memory).
read the first and last couple, should give you the jist.
  • 6 months later...
RIPS have had the car for a few months now, and the build has turned from a repair in to a full on overhaul.
I'll let the images I have selected speak for themselves!
RIPS enlarged sump
Second hand R33 block all freshened up
Standard pistons and rods
Rods have new ARP bolts
Tomei headgasket
Refreshed R32 cylinder head
Second hand valves - the last ones were bent
New inlet guides
K-lined exhaust guides
Will be fitted using ARP head studs
Front of engine
Tomei adjustable cam gears
RB25 water pump I think?
New tensioners
The legendary Tomei oilpump
Side view
In boot fuel surge tank
Two, yes two Bosch 044 fuel pumps to feed the beast!
They will feed a standard RB26 rail modified to twin entry and centre return.
Engine ready to go back in
You can see the new sandwich plate and an additional oil pressure sensor for an Innovate MTX-D gauge & the Link G4 for oil safety cutoff
The twins
GT2860R-9, but I have seen then referred to as GT2859R-9 also
Should give great response and around 330wkw on 98 and hopefully 370wkw on E85
Enough to keep me content for a while!
You can also see RIPS modified fitting at the top there.
Ethanol sensor T'eed off return line
Finally back in it's home!
Fuel rail finished
ID1000 injectors modified to fit 10.5mm standard rail
Turbosmart FPR1200 fuel pressure regulator (needs to be grunty to return the flow from two 044s!)
Thanks for viewing!
All questions and comments are greatly appreciated!
  • 4 weeks later...
