Tv, Sat-Nav What Have I Got Here?
Help please guys. Been exploring the new cars electronics and need some help working out what I have and what I can do with it. Some pics below.
So what I can gather when playing with the screen is that there are 2 TV boxes. When I select TV on the dash I get the factory box like below (TV Auto in top left corner).
When I select the TV/Japanese characters option on the screen I get the following (TV Manual)
I assume this is still the factory box but with manual selections. Select it again and I get the second tuner (I assume) Looks like this:
Anyone come across this before? Is there any other control boxes hidden in the wiring because the multi-selector on the dash controls this TV box?
Thanks in advance..
Japanese digital tv box. Rip it and fit a local one in its place. Can supply on to you if you want.
Thanks Chris. Model is DTV-M11T. Is there anything else that can be plugged into its position that could be controlled from the dash? Like a media player or the like? Is the other TV box an analogue unit?
Edited by HotXR6T
Nothing will run off the OEM controls. It will be remote only.
Is there any way to make the OEM unit default to a particular input like the information screen instead of the sat nav?
    • Hi! Is it possible to use and swap the RB25DET/RB25Neo manual gerbox on to my RB20DE Neo engine with an automatic transmission?
    • my current daily - BiTurbo Diesel SQ5 8R with a remap and some light cosmetic mods. Which is sitting in front of my old daily that hasn’t been driven in 7 years now, home to numerous redbacks no doubt. MK4 Golf GTI with a boser hood extension, air ride airbag suspension, factory RHD Xenon’s from the Japanese R32 and stubby electric mirrors (also from Japan) sitting on custom made 18x10” Work Meisters for the golf’s bolt pattern and offset. one day I’ll revive it as a project, pull the engine out, put some forged bits in, chuck a big turbo on it and tune it to somewhere around 250kw and call it a barn find to make millions off YouTube views. Till then, it is a good breeding home for redbacks and the boot is good for storing my Christmas tree for 11 months of the year.
    • Thanks for jumping in guys, suggested @Sbluatx post here for help. Was hoping one of the guys with a RWD stages could confirm if the tank was the same as the AWD one
    • I got another MAF and installed it. Idle misfire was still present. Finally got the tank low enough to refuel and did so. Did a short drive to warm the car up and no issues, pretty short drive. Going to attempt soon to take a longer drive to see. I don't think the MAF fixed it if anything, definitely thinking it was fuel related. As soon as I put fresh fuel in the car felt so much better. But, still need a longer test drive to verify. I'll report back once done.  I'm definitely going to be getting monitoring and tuning parts soon as my next upgrade (decided on the link after talking with my tuner), just been real tight with just purchasing the car and sudden onset of issues. I've also ordered a new exhaust stud kit and gasket to fix that obvious problem. Once it's back up to par I'll start with the goodies
    • Meant it’s 2WD. And my tank is cracked.
