Money pump was done recently. So, it must be that.
This is where I'd start. I like GKTech stuff, but there are more reports of that particular fan not working on RBs than there are reports of it being even as good as stock, let alone better. Also, inspect the radiator. How are the fins? If many are bent over, then you will suffer. Also look at the overall air path from grille through to the radiator core. Is it set up to allow air through the front mount to just spill out the bottom instead of going through the rad? Some corflute sheeting might help.
It's a Euro debt trap, so....just about anything? Cam drive, flux capacitor, money pump, etc.
