Air-Con Gurgle Noise
dyl33
Hey SAUers,
The other day I heard a gurgling noise from the air-con. When stopped at traffic lights and was wondering is this normal noise or am I low on refrigerant or something, Air-con is still cold.
Is there a way to check air-con refrigerant level?
How do you know it was the AC gurgling?
I'm curious to know about checking level too.
And to jump in you AC thread =)
I hear a knocking from inside the dash when I start the car and sometimes when I make an adjustment on the climate control unit.
Its only about 4 knocks then it stops.
Anyone know what that could be?
I have searched and asked several people with no success.
If it's a bubbling/gurgling noise then it will be air in your heater core caused by a coolant leak.
If it's a low pitched hissing sound then the a/c system will be low. The noise occurs when there isn't enough charge in the system and you can hear the liquid/vapour expanding in the evaporator as it passes through the TX valve.
A clunking sound behind the dash will be the servo/door blend motors/doors.
The only way to check the charge of an A/C system is with a set of A/C manifold gauges. (assuming the system has no sight glass)
Edited by White GTS-T
Sounds a little bit like both but I don't have any coolant leaks
Could be that you are getting a little low on gas. My commodore does it when it gets low on gas (has a slow leak in the compressor and needs regassing every 18 months or so).
I'm going to change coolant bleed it properly and get a/c re-gassed to be safe
