1992 R32 With Rb25Det Bne
thatjonokid
1992 Black R32 gts-t.
DRIVELINE:
-Series 2 RB25DET motor and gearbox
-Rebalanced KKR430 turbo
-3" Turbo back exhaust (from cat back is Bee Racing(Bee*R) from Japan)
-Microtech LT-16S ECU w/ MAP sensor
-Splitfire coils
-OSGiken Camgear
-Gates Racing timing belt/tensioners/idler pulley
-Sard fpr
- Walbro 255l/hr fuel pump
-Blitz pod filter
-JustJap 600x300 FMIC
-Exedy Sport tuff clutch (the pink pressure plate ones)
-Gibson motorsport custom 3" single piece tailshaft.
-Tuned by DAT performace (the guy who does the dyno at Powercruise)
-Makes 239kW at only 12psi NO LAG! Have dyno sheets.
SUSPENSION/BRAKES:
-HSD coilovers
-Bee*R pineapple bushes (subframe collars)
-KKR Castor rods
-HICAS lock-bar
-DBA Slotted rotors
-QFM700 pads all-round (outperform redstuff)
-Can provide front strut brace
WHEELS AND TYRES:
-18x10 +18 Work Emotion XD9s
-235/40R18 Federal 595s all round with 90% tread
-Guards rolled and pumped to fit the rims
INTERIOR:
-Red BRIDE Cuga Carbon-fibre Drivers seat
-R33 GT-R Passenger seat
-Deep dish suede wheel with yellow centre marker
-Microtech control unit
-Pioneer head unit with bluetooth handsfree
-Pioneer speakers all round
$9500
Car will be sold with RWC, can register at buyers cost after deposit put down if convenient for buyer.
Contact: Jono 0421 308 872
post-46140-0-40901100-1363683232_thumb.jpgpost-46140-0-83590500-1363683255_thumb.jpgpost-46140-0-97834900-1363683275_thumb.jpgpost-46140-0-39320700-1363683295_thumb.jpg
I bought the car near stock in 2007 from its first aussie owner 21000km ago, engine and gearbox came from a front cut series 2 R33 with 80000km on the clock and was put in the car just under 5000km ago
I built this car to have real world performance and be drivable and well mannered on the street, things look very stealth under the bonnet and in almost 6 years of ownership the car has never been defected. with some injectors 18-20psi and a small edit to the tune, this car would see 270rwkw+ with no issues.
car will be sold with RWC, can register once deposit taken if preferred (at buyers cost).
price is negotiable
    • I had a similar situation with my R32 GTS4. I replaced that solenoid, but it hasn't solved the problem. So its possible the pump is failing. It seems you need to drop the diff in order to do anything that might fix this. So its important to know exactly what the problem is. Or just replace / repair everything while the diff is out.
    • Yep, I was supprised. Its all about flow rather then housing size.  Doing G35-900 Vs ATR45SS-1 Next. 62mm V 61mm.
    • Of course sometimes you cannot go with the cheaper alternative but I try to weigh it up for the application - am I competing or am I going to the track ten times p/yr. As long as there’s enough information out there to back the cheaper alternative as a good option I’ll go for that.   I’m a bit of a bastard though as it’s my job to reduce costs, particularly on non income generating assets. EUR 500 saved for the diff + EUR 1,000 saved on BC racing over Bilstein and then say EUR 300 versus EUR 600 on an off brand windscreen versus OEM (for example) soon accumulates. I mean, I’m probably gonna put the car in the ditch anyway. Absolutely do not take this as a justification for always buying cheap shitty parts, just a rationale for doing your research and considering what’s necessary for your application.
    • All the above effort, time, swapping out parts in the dark (i.e. no O2 data). You're literally running in the dark.
    • Looks like both of my cars have pressure switch issues. The R32 GTR has 18 flashes on the ATTESSA controller which is "ETS pressure switch circuit". The 4WD light is intermittent, and often just restarting the car clears it. There is an $300 replacement option https://www.ebay.com.au/itm/285675135148?itmmeta=01HXN3YKRGKQ08GRZ5KFKKZWJT&hash=item428390a0ac:g:6CcAAOSwWxBltMEG so if it becomes a permanent issue and I can confirm that the switch is the issue, i have a solution. The NM35 is reporting C1208, and disconnecting the switch causes the 4WD light to go away. Translating from the Japanese shop manual "when the pressure is reduced to 2.6MPa (377 psi) or less: conduction occurs when the pressure increases to 3.8MPa (550 psi) or less: conduction is present. Reference: • Immediately after the E-TS actuator motor stops, the pressure inside the accumulator is high and there is no continuity." Not sure how good the translation is but from what i can deduce this means the switch is normally closed (NC) and as the pressure builds from 0 to 550 psi the switch stays closed, then opens and 550 psi. As the pressure drops from 550 psi to 377 psi the switch stays open then closes again at 377 psi. Is that how these things work? These pressures are a lot higher than the R32 ("control pressure 0-228 psi") but i'm hoping i can find a generic switch (like they've done for the R32) to use as a replacement. Maybe something like https://www.ebay.com.au/itm/355586397452?epid=1676016964&itmmeta=01HXN534AF22ACTG6TGDDQGEQ7&hash=item52ca99d50c:g:mAEAAOSw8ilmBcMh&itmprp=enc%3AAQAJAAAA8LtWdNlWHgyJ%2F3cbw25S2A1lde3qBi3fJii4T3lQavCz4kpqiD42SmBa4FocMvXCjcxiowHjb8vZ8%2BWxc53BkHv781tkStSnCDaenfGKC3bIp0keK20dfsn9LoPa3TfqaEmAydqqyKobgTdXsGGzsl%2BRjOVGuD8OIpOv%2B0wMl7aUtHg0iJtojbtzA%2BRS8Xfm8Ufjuvz4niwrqglAXFUbkL6J%2FGuHPeeECZhLBBN3iNM1Swl94Fv5zE95YK%2B5O6dxDN1ySNOjdMxkA8yaprbuwRHFQv1nlGh%2FWjekj6EUFR2%2FO4HTsoKtSAkY0Mj1w1uf1w%3D%3D|tkp%3ABk9SR6zFjKXtYw but with a lower close pressure, and thread adapter if required. Am i dreaming?
