Definitive R34 Gtt Wiring Pinouts
Attached is an Excel document which I painstakingly put together by hand, as I found some R34 GTT diagrams out on the internet either completely unavailable (bodyloom/m53/f3 plug) or unreliable (ecu pinouts)
Ive sacrificed an entire engine loom to get this mapped out correctly and Ive taken the liberty to add in all wire colours.
The first worksheet in the document is of what I call the 'body loom' plug or 'M53' or 'F3' plug if you are familiar with other Nissan looms. This takes all input/output from the ecu to non-engine related things. In the case of the R34 this is things like the auto trans control, traction control, dashboard outputs and inputs and power/switch feeds and triggers. I required a pinout of this plug as when going a full wire-in aftermarket ECU, many of your connections will be made at this plug. Nowhere on the internet could I find a correct pinout of one of these for an R34 GTT.
The second worksheet in the document is a standard ER34 (auto) ECU pinout, with all pins labelled as to their function and also the wire colour.
Enjoy, I hope this helps anyone who needs it. :)
R34Pinouts_Final.xlsx
  • Thanks 1
  • 1 year later...
hey man could use some help im tryn to wire a rb20det loom into my r34 dash loom plug this is the
m53 plug im sure ov it..is it the big long white plug just up from the ecu tht your writing about in your post?...
  • 1 year later...
  • 2 years later...
  • 1 year later...
Just wanted to say a big thankyou for putting this together, really appreciate it :)
  • 2 years later...
Reviving an old thread because I pulled the trigger on a wiring specialties harness for the engine side then went Haltech 2500 and a Haltech PD16. The idea being that the PD16 will effectively eliminate ALL of my fuse block and excess wiring.
I'm going to reference the excel in hopes of sorting out everything and if there's any additional information I discover I'll make and update the file. Though as others mentioned, Mitch did a great job sorting this out.
