Timing Belt Noise
AngryRB
hey, my timing belt has become noisey, i know its the timing belt because a mechanic friend dripped some water on the belt and the noise dissappeared for a day then came back, its like a SSSS-SS-SSSSS-SSS-SSSS-SSS noise if you know what i mean.
The belt is due for a change, but appears good still with no cracks etc.
Question is , ive had the front cover off and the belt and pulleys are exposed to the air, so would this being doing somthing to the belt?
and will the new belt make this noise after a short time due to being exposed too?
timing belt has done 65000k's
Edited by AngryRBGTX
I would be replacing the belt and bearings etc ASAP man, your motor is relying on it and it ifs making noises that is generally a bad thing!
heavily agreed.
Otherwise having that cover off wont do anything untoward unless you drive through a big sand dune or otherwise live in a really dusty dirty area.
Beyond this the cover can often hide noises from the cam belt system so when you remove it you can then notice noises more. (this also works the other way round like with my car where the cam cover was resonating a weird sound and this stopped when the cover was removed :S [fixed now- new rubbers])
yeah, ive got the new belt so ill take it off road til its done im just wondering if this noise will come back if i keep the cover off, i kept cover off cause it seemed noisey with it on and i broke 2 CAS's and was worry it was contributing at that time. :yes:
When you took the top cover off, did you pack out the CAS to suit?
Makes a good noise while the CAS has its guts pushed out.
not sure what you mean, i replaced that outer rubber gasket and just bolted up as normal, the sound is definitely the belt, although the engine does make kind of a mitsubishi magna sound which might be the cas?
yeah thats correct then,
Basically you cant just remove that cam cover as well as the rubber gasket as you will have seen there are basically some washers in that gasket where the CAS bolts on to and this spaces it out by the desired amount. If you put the CAS straight back on without this spacing there it can do some damage to it all.
Also, from my experience, i hope you managed to get the CAS back on exactly at the same point as it was. Mine was out (rotated) by 2mm which wound up being 4 degrees retarded. And thankfully retarded and not advanced!
Edited by jjman
yeah i put those spacers on with the gasket, i learnt the hard way and broke two CAS due to incorrect spacing and alignment and i broke the gear off the cam too, bloody expensive mistakes!
does anyone know how accurate the timing marks are? ive just taken everything off and have it all lined up to the marks, the crank is spot on but the cam wheels are both slightly off, but that might be just the way it is, probably need adjustible wheels to get things perfect???
the marks are spot on.
if they are out, i would be saying youre a tooth out somewhere.
get your mechanic to check it if youre not 100%
With my crank at TDC both my cam marks were about half a tooth retarded. Dialling them in they were 3.5 degrees exhaust and 6.0 degrees inlet out. Marks lined up after pretty much spot on after
really?
mine were spot on.
not out in the slightest.
go figure....
maybe the old belt must be a bit stretched because its a little shorter and was bloody hard to get on it and now its pretty much spot on, the exhaust cam looks slightly advanced but close enough.
i have the same noise too not sre if its timing belt.Sorry for hijacking didnt want to start a new thread.Im thinking either not enough lubricant in the ldler and pulley or too tight. Anyone familiar with this noise?
my noise was more of a hissing, but the noise you have is what i had when the top cover was on,
could that top cover be getting rubbed by the belt i wonder? id really like to get to the bottem of that noise
    • Once you go non OEM DBW e-throttle, you'll never go back to a cable throttle. Just so good in every single way.
    • Feels like most tend to keep it under 8000rpm for hydraulic lifters. Quick search on the net and those on Rennlist like to keep theirs under 7500rpm, Speed Talk under 8000rpm. Perhaps start to take timing out for 7250rpm and soft cut it by 8000rpm.
    • Ok, so I just had a chat with my mechanic. He said there is no real source of lead in the engine, the bearings and pistons are aluminium and the rings I think he said are steel. He doesn't recall what additive he used but that along with the thicker 20w50 he used could be a source of lead. It's put me at ease a little bit and I guess I'll just have to wait 5000 k's to do another change and see if anything is different.  I appreciate you guys chiming in. I have a habit of immediately thinking worst case with things like this.
    • Finished street tuning it to 20psi with WMI. Haltech really makes it easy for you with those 4D maps. I have 17psi springs in my gates but they seem to only start cracking around 17 and taper off around 19/20psi. I was originally on 14psi springs but I'm expecting to need ~35-38psi to hit my goal and I was worried It wouldn't make it. Dyno's booked for next Friday. All I have left is to replace my el cheapo amazon special type k connectors on my EGT's. They have no strain relief and well are just all around cheap compared to what I use at work. I had the wires in one get lose and I don't want a repeat of that on the Dyno. I also want to figure out why I have 4 cylinders that are perfectly identical, one that's 30C over and another that's 30C under. I'm chocking this up to EGT position in the runners not being identical and will verify that as well. Wish me luck! Hopefully I make all the power with no bang. Question for the group, I have my rev limiter set to 8000rpm. I have a fully built head and new lifters but I stuck with hydro's. Is 8000 fair or am I being to cautious?
    • Anyone used A to Z Imports in Goldcoast?  I was referred to them for engineering and RWC? However besides a few one off bad google reviews it all seems pretty legit?   https://www.atozimports.com.au/
