R32 Gtr/gts Race Components
Components for sale are as follows, all parts are located in Tasmania I'm happy to arrange freight with either fastways, express post or tas freight depending on weight and size.
I'm not on here often so please contact me via email or mobile as listed. I'm happy to send picture message or picture in email of parts to genuinely interested buyers. I have many more parts that are not listed please ask as I have not listed a third of them. Cheers brad
[email protected]
0419362110
Holinger rd6s sequential gearbox (rwd). (I have ratios on gear chart) has just been serviced by Holinger with rb bell housing and Holinger adaptor has rear mounts to fit r32 gearbox to body and lever, this box has internal pump and gear position indicator $15k
Holinger flat shift knob brand new still in packet $700
Chrome moly tail shaft to suit rd6 into r32 $1000
3 sets of rays Gtc 18x10 wheels two sets are gold face 1 and one set silver face 2. $3500 per set. face 1 have p12 offset and face 2 have p22 offset
1set of 18x10 rota grid bronze wheels p15 offset, have had tyres fitted but never mounted to car $800
Gtr rear diffs 3 in total all have Tomei centres all are 4.1 ratio all have gtst style flat pinion flange but I can swap to gtr pinion couple if required. One has done 2 meetings since new bearings, one has never been in car since full set of seals and bearings and other is good but never been rebuilt by me $ 900 each.
Nismo gtr diff centre 1.5 way has done 4 laps only $500
2 x Greedy rb25 inlet manifolds genuine not copy $900 each
6 boost rb25 to4 split pulse manifold with NO waste gate outlet fitted brand new never fitted or used $1000
Stainless xtr manifold to3 flange (is thick wall 3mm from memory cost $680 from gcg) has been on e85 and has no signs of cracking has tial 44mm waste gate flange $300
2x tial 44mm gates with 1 bar springs $200 each
Turbo smart 60 mm waste gate new in box $600
Tilton 7.25 twin plate rally clutchs. 1 brand new $900 1 used but good $400. Both have ugg diaphragm and will hold over 550 rwkw
Alloy rb flywheel with steel friction face to suit tilton 7.25 clutch $350
Precision 6466 cea ball bearing turbo brand new with 1.00 and .84 to4 v band housings never bolted to manifold $2000
Gt35 1.06 rear t04 split pulse turbine housing v band outlet brand new $380
Gtr rear drive shafts 5 sets in total $250 pair
R32 gtr rear hubs $125 pair
Rb26 rocker covers 3 sets $300 inc front cover with standard baffles $500 inc mines spec baffles installed in two sets
Gates racing timing belt kit with idles brand new not opened kit $165
Alcohol injection systems water meth kit with controller $400 (has black fuel cell looking boot mounted tank with pump mounted under, assorted jets and instructions.
Rb25 cometic head gaskets 0.51 thick 1in 86 mm bore 1 in 87mm bore. $220 each in new packaging
2 x Tomei oil pumps one new in packaging $1400 one s/h unmarked I have it unassembled and can send photos $1000
Race pack logger dash $1200
2 x Vdo diff and gearbox cooler pumps $100 each
Complete ap brake kit touring car 370 mm 72 vain 36mm thick rotors and ap 5555 6 spot calipiers on floating bobbins. Rears 330mm on alloy hats (will work with std handbrake shoes on r32) 4 spot ap radial mount calipiers and cnc mounts to fit. Kit cost 12k sell for $7500 inc spare front and rear rotors
Carbon r32 doors with lexen windows and custom made window supports. Have locks and outer handles with alloy sheet inside trim and pull cable release inside. Lh has Naca duct and rh have two pop out gt40 style vents. These have ganador copy mirrors. $2k
R32 ganador carbon copy mirrors brand new in box $80
Carbon r32 boot with touring car carbon wing $1500
Earls 34 row oil coolers 1 brand new in box, one has been on engine can show photos of bearing out of engine, 100 percent clean . New cooler $400 , s/h unit $250
Incar twin sway bar quadrant to suit lever sway bars never used $400
Rb25 head stud kit used $120
Rb Tomei adjustable inlet cam gear brand new $100
Nissan gtir sr20 turbo compete on manifold $300
R32 full genuine flare? Kit goes on In front of rear wheels and under sill. Not sure what its called but has many components offers is missing one small piece the size of your hand on lh side. No idea on price but text me an offer
Rb igniters, crank sensors, neo bottom ends, rb 25 turbos, stock manifolds. Starters, alternators, abs sensors, gtr rear wheel bearing Assms, new rb25 valves and springs in packaging, new rb25 genuine valve springs, harmonic balancers,
  • 6 months later...
Hi There,
I would like to buyone set of Rb26 Covers with mines baffles.
I would also like an intake manifold and turbo top pipe (as I am going to do a custom paint job for my new engine build).
Can you supply me a total cost delivered to Kew, Victoria, 3101.
Ev
