Front Mount Intercooler In A N/a Worth It?
By robbo_rb180 · Posted
Try matt spry or 101motorsport If not I think gt auto garage would be the next closet to the Gold Coast. -
Opportunity to convert to R35/370Z coils, those coils are more trouble than anything else. OEM (including R35/370Z) or Splitfire are the only sensible options. In the past when I was a broke lad in my 20s, I bought brand new colourful (won't mention the colour, but it's similar to my skin) looking coil packs and 2x actually came DOA! Ended up buying used Splitfires and instantly fixed my misfire issue.
