20 Inch Chrome Lowen Hart Show Rims
Nice, they are pretty common mods in the US. Have been considering sway bars for my Q50 Hybrid. Given it is AWD, I don't really have any wheel hop issues on hard launches, so I am not sure the diff brace would help as much as it did for you. I'm surprised the diff brace made any difference to shift feel, since it doesn't impact the auto transmission in any way, if anything I would have expected to feel shifts even more as there is less 'give' in the diff mountings to soak up the shift shock. Are you sure this one isn't placebo?
Once you go non OEM DBW e-throttle, you'll never go back to a cable throttle. Just so good in every single way.
