V8 Lexus Soarer Cheap!
hi there
im selling my auto lexus v8 soarer, selling as the gear box needs replacing and i dont have the time or money to fix it.
this car has always been great and this is the first problem it has had while i have owned it, the engine runs great and the car handles very well for such a big car as i have fitted brand new HSD coilovers it is very low but can be adjusted easily.
this car is also fitted with an extracted true twin 2.5 inch exhaust with blast pipes at the rear so it sounds great! it is also currently wearing a set of 17x9+15 zenki rims with some gutter rash but otherwise look good
this car also has a flip up dvd screen and decent speakers.
there is some body damaged but this car would be perfect for someone who has time to replace the gear box and wants a fun car that looks great.
also more than happy to put more rego on it at the buyers expense
price is $1500 but open to offers
thanks for reading please feel free to contact me anytime, either pm me on here or text 0425416020 or email [email protected]
    • Both of those things are on my to do but not quite in a position to do that just yet until I can at least get it running back to stock. Going to work on getting the exhaust manifold gasket and studs replaced first, an obvious need it now. Then I'll try out the new maf and see hownthat does. After that I'm thinking cas if I'm still having the same issues. Still need to run the fuel out and refuel I'll change the fuel filter tomorrow along with cleaning the iacv with carb cleaner. If all else fails I'm going to get a serial port and see if I can get some sort of data on what the ecu is seeing when the issue is happening but really hoping one of the methods above work out first. After I get a good base I'm going link but have to save for that so it'll be a while for that based on my tuners suggestions. Definitely need the exhaust leak fixed first though car has always fallen flat after about 4-4500 rpm since I've had it and suspecting that's the issue. Then I can move forward with the rest.
    • My vote is rebuild s2 engine or maybe get a neo (but expect you may need to rebuild that too). Doing an engine conversion you would have to be a true tragic nowadays and actively be aware there's better/smarter options for value.
    • Or buy one someone built earlier! (realistically V8 mustangs or MKV supras are great). I see people nowadays putting ZF8's into MK4's, and people putting 370z gearboxes, diffs, axles into R and S chassis and it's like.... just get a 370z at that point and mildly boost the 3.7 instead of the 2L and away we go...
    • If you're going to go v8 or really any swap now with all the tax, I'd most likely just get rid of the car and start with something else. Unfortunately, I have a mate with a surplus of ls and Ferrari/Maserati v8's that's always tempting me FFS lol.
    • If you can get a clean, tested neo from Japan for $3500 these days, it's probably worth getting either way, hard not to be skeptical at that price. Otherwise probably rebuild the s2.
