Any One Chasing An M35 In Perth?
Ross
I'm selling up my stagea, if anyone over in perth in looking to get one hit me up via pm.
Priced to sell $11500
I believe this is the cheapest m35 available over here.
Sorry I forgot to mention the exhaust is now stock and will have standard state license plates (not personal plates)
Although It does come with 19s, tein coilovers, front underbody brace, aftermarket DVD screen( not in photos) and the brakes
Edited by Ross
    • Have you seen the Milwaukee Train Horn? It's a beast! I stumbled upon it while browsing for upgrades. I'm thinking of adding it to my ride for some serious sound. Here's the link if you wanna check it out: https://bosshorn.com/products/milwaukee-train-horn. Anyway, thanks again for sharing your method.
    • Anybody home...? I used to moderate this part of SAU about 20 years ago... hard to beleive it's still around basically unchanged with all the old posts pinned at the top. Amazing to read all those posts again.  If anyone drops by, I'm still in Japan (Nishinomiya, between Osaka and Kobe).  Cheers 🙂
    • Ah, yeah, the diff bushing in the rear subframe, this has been a problem since the start of the V35 in the early '00s and the only solution ever offered by Nissan is a whole new subframe.  Since they are fluid filled, as soon as they form the smallest crack, they leak brown fluid everywhere.  The aftermarket options for the v35 and V36 aren't suitable for the V37 either, Z1 has built an aftermarket option, but a few people have had issues with it. The brace should reduce movement in that bushing, so should extend its life! Did you notice any increase in noise from the driveline?  I know some have installed solid subframe collars and complain about the amount of noise it transmits through to the body, but not sure if the diff brace makes any noticeable difference?
