Sau Show And Shine Pics
AGE
  • Replies 254
Thanks for today SAU.
It was nice to get my car out for its first Victorian outing.
Was also great to have a look at so many nice cars.
Here is a link to my Photobucket album with 70+ photos and a sample of a few can be seen below.
http://s5.photobucket.com/albums/y194/swilton75/SAU%20Vic%20Shown%20n%20Shine/
