Tom's C33 Laurel
Thomasino
So I picked up another handbrake (one that had a ratchet in it so I can actually park with it), tail shaft and a steering column with a boss kit for my nardi and solid steering bush on it. Boss kit seems to be seized to the column so soaking in WD40 and attempt to remove tomorrow. Also sold the gearbox back to the guy I got it from as it was missing a few bits and pieces and bought one straight from a car with slave, all plugs, cross member, clutch fork and shifter assembly. Then ordered a few bits from GKTECH; shifter, drift button (handbrake has no spring), clutch line and subframe slip on collars.
Attempting the conversion this weekend. Neither myself or my mate have done it so going by the good old trusty internet forums on how to do it. Bound to run into a few issues which hopefully can be cleared up quickly (so, I may be posting here/PM'ing people...). The main thing I'm concerned about is the wiring. I was given some piece of loom with my pedals and clutch which was supposedly needed for a manual swap, assuming this has something to do with the reverse lights. Hoping it all works with the current auto ECU and bridging the Park/Neutral switch isn't too hard to find and do.
And on an unrelated note, had a 'close' call with a motorcycle cop recently. Followed me home off the main road and warned me that my indicators were flashing fast, and they may exceed the maximum allowed flashes per second. He told me to check for LED/blown globes as this will cause it, but I can't find any, so not sure what the issue is. He also asked what the hell my hang ring was, then told me I should probably take it off as other cops might thing something is broken and pull me over, so its now been put to use as a Jesus bar. Was a pretty good guy about it all, didn't mention anything else about the car.
And finally I'm considering changing the rims. While the 15's with 195/50/15's are baller as, to pull them off properly I need to slam it at least another inch, and driving it how it is is already pissing me off, scraping everywhere and smashing into parking bays. So considering these...
Buddyclub P1's, in 17x8 +22 and 17x9 +37. For reference, not sure on the below sizes:
More updates over the weekend I'm sure.
Tom.
Edited by Thomasino
I tried a set in that colour on my 32(which is the same colour as your laurel) , gold/bronze didn't suit imo :) . As for your indicators , make sure the one in the front indicator is a t15 , Alot of peeps put t10s in them and that makes them flash fast
Well today was reasonably successful. We got all the auto stuff out and all the manual stuff in apart from the handbrake and electrics. Need to continue bleeding the clutch (taking ages) and have a better sus of the wiring. I bridged the park/neutral plug but haven't started it up yet. The wiring loom I got with the pedals (R33 parts) has different connectors for the reverse and neutral plugs on the RB20 box. Can anyone tell me why you need a neutral switch on a manual gearbox? The idle RPM doesn't change when its in or out of gear on a manual does it? We also need to figure out which of the two plugs goes to which on the gearbox, trial and error for that one due to spliced cables.
Few pointers for anyone doing this conversion:
Clutch pedal:
I had an R33 clutch pedal which had a piece of metal tack welded around the threads creating a cylinder around them. I also had this same piece inverted and tack welded to my fire wall. We ground the piece off my pedal and left the one on my fire wall to allow for enough thread to pop out to the engine bay but as it turns out, this one was longer. So we ground it off the fire wall and left the original one from the pedal in place.
Gearbox cross member
The auto on the laurel has the cross member marked 'A'. The one I got on the R32 manual gearbox was marked 'C'. These look identical to me, and do not line up with the holes under the car. We elongated the holes on the cross member in order to fit 2/4 bolts on just to hold it in place until I can get a cross member marked 'B', which apparently lines up.
Auto out and manual in the back ground. You can see how the left of the cross member (even unbolted and hanging there) raises up higher then the right. The holes would line up if it was span around but because of this shape, this will not work.
A and C:
Speedo cable hooked up, cross member off:
Elongated holes to hold for now.
Electrical
I'm not 100% sure with this as I was given some wiring with my pedals/clutch and told I need it. This loom I was given basically consists of an 8 pin connecter at one end with an earth coming off the loom about 5 inches below, and at the other end just two 2 pin connectors. I also had a short, thick earth cable. Does the gearbox need to be earthed tot he chassis? The 2 pin connectors are for the reverse switch on the gearbox (assuming this turns my reverse lights on) and the neutral switch on the gearbox. The 8 pin at the other end (I haven't done this step yet so may be incorrect) is for one of the 4 connectors next to the fuse box behind the battery. It should only fit in one. Two will remain empty. One has two thicker wires coming from it (this connector was at the bottom of the group). I believe this is the park/neutral safety switch (ie a switch in the gearbox is engaged when the auto is in park or neutral, allowing the car to be started, and disengaged when not, disallowing the car to start). These wires must be cut and soldered together to simulate the switch being engaged 100% of the time (ie letting you start the car).
If you follow the loom from the auto box up, you need to unplug all the clips here except the thick white cable with blue stripes as it's not part of this loom.
4 clips undone. The large one on the right with two wires is the one I bridged and will plug back in.
Cut and twist:
Solder and heat shrink/tape:
RB20 gearbox. Yellow cables and connector is for reverse switch, far right black cables and white connector is neutral switch. These are the ones I'm not sure which of the two on the loom I have to connect up to. I'll just have to guess and test the reverse lights.
Spigot bush
Not easy. My mate (mechanic) had his doubts about this step as his spigot bush pullers could not get a grip on the auto bush to pull it out. To make things harder, the auto one is thicker, deeper and made of steel, not brass like the manual one. I googled the problem and found 10x the amount of results as I could with a general manual conversion search. A lot of people suggested putting dry lube, grease, Plasticine, wet newspaper or even wet bread into the bush, and shoving a bolt or metal rod that juuuust tightly fits in, squashing your chosen material at the back and hydraulically forcing the spigot bush out. However many people found this didn't work on the auto as there is no room behind the bush for the material to get to and push from, if there was, a puller would do the trick. Others suggest drilling into it and basically smashing it. Click here for this method. We just hit it with a hammer around the edges to break up the joint a little and kept using the puller to get it out.
Drive shaft
I used a manual drive shaft from a HC33 Laurel for a perfect fit. I have read that the front half of a manual R32 can bolt to the rear half of your auto shaft at the uni joint.
So that's all for today. Tomorrow we will try to finish bleeding the clutch, start it up and mount the handbrake. Does anyone have any advice for this? Can't seem to find any marks on where to drill/weld. There is 3 dimples on top of the trans tunnel but the handbrake only has 2 mounts, and one is on an angle, to be mounted on the side of the trans tunnel. We found a 'flat' spot on the side but mounting it here looks like it is pushed too close to the gear shifter. Where does the cable go through the trans tunnel?
I also have a solid steering bush to put in, rear subframe slip on collars, boss kit for my wood grain Nardi and then to raid a half cut and hopefully get the rubber gear boot and interior pieces I need!
Any advice before tomorrow would be appreciated, if not, I'll be googling a lot tonight...
Tom.
Edited by Thomasino
when i did my manual conversion i got the gearbox loom with it and it just plugged straight in no soldering required at all.
as for crossmember the standard auto crossmember fit up fine i believe.
you probably should have done the hand brake before the gear box. im not sure home much room is up there with the box in but you need to drill holes and put nut and bolt with big wide washers so you done pull the bolts out when you rip the hand brake up.
i believe when we did mine we had to cut the mounts off for the foot brake release then just slipped the manual hand brake up to the panel join and bolted it down.
i tack weld a slide hammer on the spigot bush , carefully , works a treat! . i can't remember which Gearbox crossmember i use , but it fits perfect and bolts in the factory position , i think it was r33? . hope that helps :)
Well, the car runs and spins the wheels in all gears, haven't driven it yet. I haven't used that loom yet, only put back in that safety switch I bridged. So no reverse lights and haven't seen any idle issues as we only had it running from cold to test the gearbox worked.
Don't quite know what to do with this heap plus the gearbox. Is it worth selling or should I scrap metal it and hope to make some spare change from it? The gearbox is bloody heavy.
Got my Nardi on. Still need to remove foot rest as it's a little chunky and gets in the way sometimes.
Pretty bad photo but for anyone's reference, the markings for this part of the handbrake were on the chassis. We just drilled and ground our way through and then bolted it down.
And then guessed for the leaver. Once that back section was in it gives you the right length, it's just the angle. Going off photos that Danny sent me I had to guess a spot.
We also put the GKTech slip on collars in yesterday.
Now have injectors and fuel rail out for a clean while changing the leaking seals. Hopefully sourcing some interior pieces and possibly cross member today.
Edited by Thomasino
handbrake: find a written off r32( maybe r33?) and remove the h/b mount by drilling the spot welds out then weld bolt on trans tunnel
gearbox mount: a) bolt up the box x-member normally and make up adapter plates by drilling flat bar and using that to offset the difference bolting it up on to mount and to the box
b) mod the x-member by cutting the sides down so u can weld up some C Channel under it so both holes can bolt up to the body
I'm thinking the current setup will hold for easy driving, ie wearing clutch in, getting the car home. Definitely won't be doing any clutch kicks, hard shifts or extended periods of driving. Getting a B cross member is a priority.
And Danny still no console but haven't gone to have a look at that half cut yet. I'll definitely let you know if I need one.
Nice work mate.
Auto spiogot bushes are the worst!
I've got buddy club P1'S on my cefiro, 17 x9 +27 and they are flush with rear guards at 90mm ground clearance and (stock) rear camber arms set to max positive.
Same size on the front and with R33 LCA (so about 15mm more track each side) they poke around 10mm with 2.5 deg neg camber.
Anyway, the ones you posted (17x8 +22 and 9 +37) id expect to not quite sit flush with the guard, assuming cefiro and laurel guards have similar dimensions
Try the P1'S you have access too, see how they fit. They are a light wheel, lighter than my R33 GTR rims
Got a cefiro gear surround in at the moment and no center console yet, I think Danny's gonna help me out though.
Got my B cross member in the mail today and it lines up perfectly.
Now I need to find an intercooler pipe with a blow off valve attached, manual makes the no BOV flutter so much worse then the smooth power delivery in auto.
    • I don't know if this is accurate. The EPC places the EPS control unit somewhere in the engine bay or somewhere in the interior near the firewall, presumably because the things it's controlling mostly live up in the front of the car unlike HICAS which has a whole steering rack on the rear axle to handle. @D.phantom The R32 GTR manual actually has more than I give credit for talking about the non-HICAS cars: You can probe the pins on the diagnostic connector directly to read the EPS solenoid voltage as far as I can tell following the flow chart.
    • Hi all, so I bought a very low kms 2019 Q60s in Nov 2022 and have been driving it stock for 17 months. The power from the VR30DETT has been a little scary as these cars did not come with a LSD. Although the ECU does well with compensating the lack of LSD by using automatic braking on different wheels when there is lost of traction etc, it does not really give me much confidence to push the car harder. Further to that, the car feels quite boaty especially around sharper corners or roundabouts - it would seem like the wheels are lifting on one side. These engines are also very prone to heat soak as the heat exchanger is tiny. I felt this during the heat wave in WA over summer even in normal driving. Gear shifting in the Q60 is also something that I hated - it's quite harsh at low speeds especially in traffic.  I recently purchased a set of f&r sway bars, rear diff brace and a heat exchanger from Z1 in US. Here are my thoughts 1) Rear diff brace - no more wheel hop when accelerating quickly. wheel spin still present but manageable comparing to before. Gear shifts are now smoother, you can still tell its shifting etc but you dont feel the harshness. I would highly recommend this mod, and it should still be on sale at Z1 at the moment. 2) Sway bar - there are 2 settings for this F - 114%/165% increase in stiffness over stock and R - 138%/214% increase in stiffness over stock. Currently I am on the stiffer settings. The car feels very planted. Due to the weather over here I have not been able to test if i need to reduce the stiffness. So far it's much more comfortable to drive over stock as you dont feel like your car is lifting up and in fast turns you can control the car a lot better while turning left and right in quick succession.  3) HX - the Z1 HX has a much higher capacity and surface area (up to 200% or something). Again with the cooler weather it's a little hard to tell. I went with the Z1 HX due to the price, size and colour (black). You can't see the HX through the front bumper. There is a cheaper brand but it was smaller and the rest were more expensive which i didnt think was worth the extra since I won't track this car much at all. All 3 mods were easy to install, all plug and play. Note of caution, the front bar needed to come off for the HX to be installed.
    • A is the HICAS CU.  As far as I know, there are no other modules located at A in a car with HICAS, so it is fair to presume that F is the variable power steer module for non-HICAS cars. Same location, give or take. Makes sense - the wiring loom for the HICAS cars has the speed signal, power, solenoid drive, etc wires all present there - so why move the module and have to upend the wiring loom?   Having said the above though, it may be the case that F is further down in the rear guard - it's hard to tell. In which case it may be something else. Yes, it is the multi-pin plug next to the under dash fuse box. Top left corner. Can't miss it. Be very careful though - use insulated probes to poke around in there so  you don't accidentally short 12v to ground or an ECU input etc etc.
    • They didn't. This is their comments; I'm not sure why they don't have the OEM specs.
