All New * Walbro * 460Lph E85 In-Tank Fuel Pump + Strainer Kit
So I've been asked by a few of you what makes this pump E85 compaible unlike others, here are two reasons;
A lot of pumps mainly BOSCH unit's are used with E85 today, in most cases there life cycle will be around 500hrs (w/ E85), these Walbro's have an expected lify cycle of 3000 hours (6x more)!
Secondly, if a pump design has exposed electrical terminals it is certailny not to be used with E85 fuel.
There are more but that's the two main ones.
  • Replies 59
Would there be issues getting the pump now at 280hp then down the track it wouldn't need changing when the car is doing around 400hp?
Hey!
I don't see any issues with that, only thing is in the short term the pump would be overkill for your set-up.
It would still function correctly.
- Brendan
dam i should have got it from you.
would have saved myself 20 bucks.
ah well.. :(
next time.
So anyone got any proof of this pump holding over 500hp would really like to know as i'm going to be borderline 500hp after my new setup goes on
Jem reckon 350kw is borderline for the pump so i'm real curious
Edited by sultanaz
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
    • Because it's rubbish, it got progressively better with each generation but still rubbish when you're pushing the car on the track. Some like it, most hate it.
    • Yeah, I presumed that the pic was of some other car, because of the F. Ikeya arms.
