M35 Coolant Bypass Kit
scotty nm35
I have been testing a few of my bypass kits out on my car, Cam's PM35 and a turbo V35, all showing good results. Hopefully Cam can add his logging data to the thread later.
It consists essentially of a hose connecting the block to the coolant return line back to the radiator via the heater hose. I decided to fix the air bleeding issue at the same time, with a ball valve for easy filling and purging. I was hoping to make up some funnels to screw into the ball valve also but they aren't really required. The pushlock fittings aren't cheap and I still need to get quotes for the laser cut alloy block plates so I have no firm pricing as yet, but I need to gauge interest as I don't want to get many more than I need cut.
From my testing this kit makes filling the coolant simple, just top up the radiator, start the car, then fill through the ball valve. One closed it seals the system but allows simple air bleeding as required.
It allows more coolant to circulate through the radiator, keeping temps much more stable. I have done a few track days recently and although the temps rose it was much less than I would usually see, and the stock radiator I am using was coping well. (shame the gearbox didn't stay as cool.) On the dyno the coolant temps were more stable and when pushed it would rise, then drop back to normal straight away making the tuner more confident with multiple high power runs. I feel a larger radiator would still help keep the track temps under more control.
Here are a few instal pics, the hose will require heat shielding from the exhaust as you can see.
  • Replies 46
I know you lot don't take me seriously lol.. But this is seriously something a lot of you should be getting on to. Especially after seeing what the little bottle like thing looks like on the head..
And you sell it so well.
Why did you have a bottle on your head?
No timeframe as I have no time. lol.
I need to get the plates laser cut, once that is done the rest is fairly straightforward to make. I might do a small run of 10 for now and see how I go. I'm guessing around the $250 mark for the complete kit, hopefully less if I can get some better pricing. Obviously buying in bulk would be smarter too. Anyone got contacts at proflow? :)
Tease! :nyaanyaa:
Sounds fine, I'm down for one. Let me know when you've worked out firm pricing etc. Good chance to chuck in the Nismo thermostat at the same time.
The Nismo thermostat is a 5 minute job, this kit will take a few hours Ryan. The injector rail and lower plenum will have to come off. Not a difficult job but time consuming.
I can make one and send it over if you want it soon, I think I have enough parts. Are you able to take some pics and write up an install guide to help out the other guys? I can work you through it on the phone.
Didn't Cam take enough photos for install guide?
The time it takes to complete the job is rewarded, coolant temps are very stable and the fact that you don't have to tip your car upside down to bleed the cooling system makes it worthwhile
Check out http://www.anfittingsdirect.com/index.php. I had a quick look & couldn't see weld on fittings, but maybe there is a way around by being creative? Prices look good compared to other suppliers & a decent order (for 10 people) should only add $5 for each person.
N/A if they don't have the bits you need, but possible source for other projects perhaps.
They only seem to sell teflon hose connections Leon, I have this hose but it is more expensive and also not very flexible. It also has a lower recommended heat rating. I think the rubber hose with pushlock fittings is a better way to go.
I agree, rubber hose is better for this situation. Sorry, I didn't look very hard at what they sold.
Edited by Commsman
    • Turbomachinery engineers. They're just mechanical engineers who generally studied in universities focused on oil and gas, aviation or that had a formula SAE competition team. We have an entire team of them in our engineering department... they geek out over data and performance testing. I worked with them a lot when we developed an anti surge system for centrifugal compressors ran by electrical motors (~20 000-50 000HP) to avoid surging on accidental power loss.  They laugh when I mention automotive turbochargers.... it seems they're lightyear's behind in technology due to poor funding. If you think formula 1 spends a lot of money, a single turbine/centrifugal compressor package in my line of work including the balance of plant equipment generally ranges in the 150-250Million range depending on size.
    • The diff brace did not increase NVR at all. And yea the whole reason I thought getting the rear diff brace was a no brainer was because of the reduction in wearing the bushings out + wheel hop. It's a cheap mod for a big cost mitigation in the long run. I bought it for $99 USD + shipping. In regards to the sway bar - i had some over/understeer going on but i just checked my tires and they are pretty worn out. I wont be changing them til july since i'm away for work for a month or so. will sort it when i get back and do more testing. But its definitely still a big thumbs up from me given how planted the car feels now and me being able to go around corners quicker. Still puzzling to me why they never put a LSD into these cars....even the 400z. I saw this mob selling LSD kits for a decent price though it's a little more involved on your part to get it installed: https://www.tractionconcepts.com/Infiniti-Q60-R190-Limited-Slip-LSD-Rear-Conversion-p/tcxin9240.htm
    • Great for thrashing on the track - particularly if it is all corners. Otherwise, it is a recipe for massive tyre wear and reduced straight line traction. -1 is plenty for a streeter.
    • There are other MAP tapping ports. There's one that runs to the boost gauge MAP sensor on the firewall (over in the corner behind the brake booster). Start at that sensor and follow the hose to the plenum.
    • Japanese circuits have always looked tight to me on Youtube vids. They seem to be able to fit tracks into the smallest of spots. I've never experimented with camber in the rear. I'm running similar front camber to you (albeit in the E90) but I've been looking into what options I have in the rear. -3 rear seems like a lot. Yeah, mine is the N54. I had an N52 330i for about 7 years, it was awesome but I just needed a little more poke. The N54 is also DI. I'm running BC coilovers with the M3 front arms and a Whiteline front sway bar and the turn in and ride quality is brilliant. But I do still suffer from a bit of roll so I've been looking into that lately.
