Cheaper Turbo Manifolds. I Know Sigh
dyl33
I don't think anyone credible has ever said it CANNOT hold over 300.
I do believe that it has been said it can be used for up to 300kw applications. I think thats a reasonable comment.
Reasons:
Above 300kw there would definitely be markable gains from a quality manifold.
E85 is a game changer because it makes for a cooler burn (alcohol) and therefore counteracts the restriction of the stock manifold to a certain degree.
So I guess the BS is that the stock mani cannot hold much more than 300rwkw.. :whistling:
now, now..hold your horses...i first thought this aswell, and yes one of my mates has made 350rwkw on a 3076 56T .63 at 17psi on e85 atm, still has some left in it
stock mani with gate of exhaust housing
I first thought it was a octane issue on 98 that capped things at 300 with that frame of turbo..stao said no its the manifold..well
we are both right..it is octane limited to around that mark on 98 with a a stocky, but change to aftermarket and you can add some timing due to no restriction and pick up a very good handful of kilowatts
E85 is a game changer..it has so much octane that you reach mbt with the timing curve with those turbos whether you use use
a restrictive manifold or not and still have plenty in reserve..it woudn't suprise me if there wasn't much difference is peak power between
a aftermarket or stock in that scenario..i think my mate will try a nz hybrid mani soon so will be interesting to see the difference or how
the curve is changed
darren
Edited by jet_r31
glad i have a stock manifold now, got pulled over by cops this morning and they had a good look under the bonnet, was shitting myself... an aftermarket manifold would not of helped.
Heads up, for people thinking about buying the new Hybrid low mount manifold (no wg).
This is a good quality manifold for the price but it won't fit your rb25 motor without modification - studs, washers, nuts and bov/intake piping.
I bought it because it's based on the HPI design which is bolt on, but that's not the case.
I've contacted Kam a few times now to address issues, but unfortunately there's reluctance to change the design, so I may be out of pocket.
For now I'm back to stock manifold.
Cheers.
Cheers.
I am not sure if you know how hard it is to make a manifold out of mild steel, it is not as easy as making it out of Stainless steel where you can bend easily,
There are so many tight bends to look at and getting everything to line up with the std position of the turbo,
Having to trim a couple of studs and using 2 washers slightly smaller in diameter is not a mission, this is a custom made manifold it took me 2 weeks to do it for you and to make it look and perform well, having to modify the couple of things which is only trimming the 2 studs and modifying the bov return line is nothing major, as any one would know when dealing with any after market product you will have to make some changes and these are minor,
I have emailed you back every time you sent me an email and even offered to sort something out, if i don't reply in 5 minutes i am not ignoring you i do have things to do as well,
kind of frustrating having to deal with this kind of stuff specially when trying to do something good for some one you still end up getting biten and loose your time making something.
Yes it's frustrating but not many people will want to change so many things to get it to work.
I'm not biting you, what you thinks needs to be done, workshops will charge a $%^load to fix, studs and piping.
If it takes more time to get manifold to bolt on and you feel confident this is worthwhile, as I've said privately I'd be happy to purchase another manifold.
I'll be taking up your offer for the refund, minus postage.
Cheers.
  • 11 months later...
Hi Just thought i'd give these guys at Hybrid performance the benefit of the doubt with regards to their manifold and guess what
its a piece of S#!t that is built poorly...i even asked if i can get a refund and KAM said no refunds look on the website lol
His stuff is cheap and the quality is crap
Save yourself the trouble and buy well known and trusted brands
Hybrid Performance is a scammer and should be banned from SAU for trying to sell its products
I actually should have spent my money on a on a stainless steel one
Hmm, my Hybrid top mount bolted up with no issues. I did modify the wastegate port slightly but that was due to me obessive complusive disorder with my car, i wanted it a few CM further away from aircon lines
mines seen about 5 track days with 320 rwkw with no issuse except a bit of loose dag in the manifold which i removed with dremel. wil see how the manifold handles 350 with e85
