Nitto Oil Pump Redesign?
  • 4 weeks later...
I will be having a chat to NITTO when they come to my shop i a few weeks. Told him to bring heaps of info on the new spline oil pump setup.
Will post up once ive had a chat
I've got one of these. I'll probably go and pick it up tomorrow.
They just had a re design and a few small changes. The big change is the gear set is now dura finished.
I will be having a chat to NITTO ehen ghey come tomy shop i a few weeks. Told him to bring heaps of info on the new spline oil pump setup.
I like the sound of this
Translated it says
I will be having a chat to NITTO when they come to my shop in a few weeks.
Will post up once I've had a chat
I cant bring myself to buy a new pump like this, just like any new piece of equipment or hardware there are flaws/bugs atm whoever gets one is a test pig in my eyes and dont go disputing its my oppinion
They have released the new design of the current flat drive pump. Its just been tweaked.
The spline drive pump is still a fair way off i believe.
  • 2 months later...
  • 4 months later...
Edit : I spoke to Andrew from Nitto today, and the spline drive pump is still undergoing testing .. They are happy with the test model so far , so with a bit of luck it will be released soon.
Edited by ezy_09s
    • Thanks - to be sure will the WHC34 work?  I can’t find the other one anywhere.  Thanks
