R33 Gtr Stock Handbrake Shoes (Or Handbrake Pads)
That's fair enough. Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power. -
