Performance Fuel Injectors - 1600Cc 440Cc 2200Cc 1000Cc 725Cc 875Cc 650Cc
It's 12 gauge Tefzel wire. Should be right for 20 amps. I've clamped the fuel pump wiring, it measured around 20 amps. I can't remember the exact figure, I did it a while ago now, but it was around 20 amps. Still, lots of good info in this thread now. I'll keep investigating and post back with what ends up solving the voltage problem.
