Where Can I Buy R34 Gtt East Bear Bodykit?
Also on the haltech the 2 triggers are the opposite to what you’d think is correct
thanks GTSBoy
awesome, that's exactly how mine is working, I was unsure as when car arrived none of these gauges were connected, so I had to wire/ plumb everything. good to know I did it right, thanks.
Looks like the connector itself on the trigger kit is pinned funny. Make sure you're not wired to the +12V, it should be sensor GND and back to B2 on the Elite 2500 (need to find the post I wrote years ago). -
No. My original advice remains 100% valid. Evey single CU on the car s able to talk to a diagnostic handset plugged into the Consult port. No OBD. No problem. Has Consult. PowerFC is not part of this equation. You want the codes from the SRS CU.
