Injector Identification
Hey guys,
I am trying to find out what injectors are in my 33, rb25det
I have only pulled off the cap and checked the part number and can't find anything on the net that has the same number, trying to avoid pulling them out and getting them tested.
They are a maroon/ terracotta/ red colour.
The number on them is: A46 - Z00 0127726.
If anyone knows what they are or where I can find out please let me know.
from what I have been reading the 740's are A46 -Z00 0128911. But then looking at some pictures of some for sale the numbers stamped on the injectors are different from that. Is that the case are they still 740's?
the last part of that number is probably just batch or serial numbers, they're never exactly the same.
surely you know roughly what they flow from injector duty and power? what ecu do you have?
Oh yeah, of course he is running NA injectors in his 25DET.... :rolleyes:
I have seen boxloads of NA injectors and they vary in colour from red red to browny red so no points there sorry bud..
Nismos are considered to be just RED...
While the brownish red 480cc were mainly found in the S15 "R-spec" only, they were also available in the Autech S14... :nyaanyaa:
  • 1 year later...
Sorry to dig this up but didn't want to create another thread..
I have light blue injectors. I was told they are 550cc and only marking on it is "Annam" or "Ammam" and couldn't find anything on google about it.. But then again it could say something slightly different but I couldn't tell.. :/
Cheers guys!
Pictures would be a huge help.
Yeah, sorry the car is in Brisbane and I live on the Gold Coast.
I can get some pictures this Saturday/Sunday and will post them up...
Just thought it was a little weird that I couldn't find anything AT ALL on google. :/
Cheers Zane.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
