I just did the R35 coil pack conversion with Hitachi coils. Now I'm getting TCS, slip and cel lights on. Car runs great and better than before on factory coil packs. Has anyone else ran into this issue?
haha I held off on getting a dash for a while because I didn't like the iC7, and I knew Haltech were going to bring out another dash. I just don't know how this will actually fit in the R33
