Silvia S13 1991 - Sa
Things have changed and its now time to sell the toys and buy a house :(. I bought the car around 18 months ago with the intensions of driving it on the weekend and using it for time attack. Since buying it I've driving it around 5 times one including the drive to Mallala with the SAU:SA track day where the car performed very well.
*SUSPENSION + BRAKES + ETC*:
R33 gtst front brakes (redrilled to 4 stud)
QFM A1rm fronts pads
Ebc Black Stuff Rear pads
Cusco 'AS' Front Strut Brace
Cusco 'OS' Rear Strut brace
Cusco Castor Rods
ISC N1 Coilovers with new Thrust bearing kit F8kg & R6kg
R32 GTR rear sway bar
*ENGINE + EXHAUST*:
Redtop SR
HKS GT-SS turbo in t25 housing
850cc injectors
3A racing pod
Hard intake pipe
z32 AFM
3" dump and front pipe
Air diversion panel
Nismo low temp thermostat
Oil cooler and relocation kit
Koyo Radiator with High pressure Cap
NEW Calcium battery
NEW HDI Front mount
NEW Walbro fuel pump
NEW braided turbo lines with inline filter
NEW gfb bleed valve
NEW overflow bottle
Needle Roller Spigot Bearing
-Custom 3" cat back exhaust with flutes
-High flow cat 100 cell?
-One Muffler
New Genuine Nissan:
-water pump
-clutch slave
-clutch master
-Cometic multi layered manifold gasket
-dump pipe gasket
-Manifold to turbo gasket
-New manifold studs
-New exhaust studs
-Nisstune
*EXTERIOR*:
Sun roof
[ ][ ]SILVIA[ ][ ] Head Lamps
Wing-less
Aerial-less
Gtr style Grill
Varrstoen te37 copies 17 x 9 + 12, 17 x 9.5 + 12
Federal 595 with 90% tread
Origin Roof spoiler
*INTERIOR*:
Nardi steering wheel and genuine horn
Greddy copy bucket drivers seat
Superlow seat rail
R32 GTR passenger seat
Digital Climate control
Pioneer head unit
Soundstream Tarantula 6.5" speakers
Auto meter boost, water temp, oil temp and oil pressure gauge
nismo gear knob
*DRIVETRAIN*:
NEW Braded clutch line
Turbo 5 speed box - new oil
Extra H/D single plate clutch
3.9:1 LSD 6 bolt - new oil
The bad: Body has had a respray a few years and but has a couple of marks in the paint (not noticable unless you get close), had some rust around sunroof but was cutout and fixed up.
Located in western suburbs Adelaide
Contact: 0430 362 050
P.M or email - [email protected]
    • Sure, but the result will put so little power to the ground it won't be able to move. Whatever your reason, it will be cheaper and more practical to sell the manual and buy an automatic
    • Hi! Is it possible to use and swap the RB25DET/RB25Neo manual gerbox on to my RB20DE Neo engine with an automatic transmission?
    • my current daily - BiTurbo Diesel SQ5 8R with a remap and some light cosmetic mods. Which is sitting in front of my old daily that hasn’t been driven in 7 years now, home to numerous redbacks no doubt. MK4 Golf GTI with a boser hood extension, air ride airbag suspension, factory RHD Xenon’s from the Japanese R32 and stubby electric mirrors (also from Japan) sitting on custom made 18x10” Work Meisters for the golf’s bolt pattern and offset. one day I’ll revive it as a project, pull the engine out, put some forged bits in, chuck a big turbo on it and tune it to somewhere around 250kw and call it a barn find to make millions off YouTube views. Till then, it is a good breeding home for redbacks and the boot is good for storing my Christmas tree for 11 months of the year.
    • Thanks for jumping in guys, suggested @Sbluatx post here for help. Was hoping one of the guys with a RWD stages could confirm if the tank was the same as the AWD one
    • I got another MAF and installed it. Idle misfire was still present. Finally got the tank low enough to refuel and did so. Did a short drive to warm the car up and no issues, pretty short drive. Going to attempt soon to take a longer drive to see. I don't think the MAF fixed it if anything, definitely thinking it was fuel related. As soon as I put fresh fuel in the car felt so much better. But, still need a longer test drive to verify. I'll report back once done.  I'm definitely going to be getting monitoring and tuning parts soon as my next upgrade (decided on the link after talking with my tuner), just been real tight with just purchasing the car and sudden onset of issues. I've also ordered a new exhaust stud kit and gasket to fix that obvious problem. Once it's back up to par I'll start with the goodies
