R32 Gts-T Manual Sedan
'89 R32 GTS-t Manual Sedan Light Silver
Lismore NSW
I bought this car newly complied in 2002 with 73,000 Km on the clock.
I've done a lot of upgrades and tasteful mods and had plans for big power but never had the funds or the time to take it all the way.
I don't get to drive the car as much as I'd like and have only put up about 20,000Km in the 9 years I've owned it.
Everyone that's been in my car says it is the cleanest and most original R32 around.
The car has always been garaged but now the garage is being renovated into a studio so I've decided it's time to sell it.
I've spent a lot of money on this car and also have bought a lot of parts for further mods that haven't been fitted.
These parts will be sold separately.
The mods as the car sits now.
Fujitsubo Powergetter S.S. exhaust. also has S.S. Fujitsubo noise legal muffler (5 min. to swap over)
Catco 5" metal substrate cat.
Hybrid 600x300x75mm Bar and plate FMIC with custom aluminium piping.
Splitfire coils.
NGK Iridium plugs.
Apexi panel filter with R32GTR factory intake ducting.
GTR fuel pump with wiring upgrade.
Heavy duty Aluminium radiator.
R33gts25t Manual gearbox.
Nismo transmission mount.
Heavy duty 900Kg ceramic cushion clutch.
Tomei 300KPH speedo.
Blitz RacingID boost gauge in custom pod.
Factory boost gauge replaced with factory volt meter from R32 non-turbo.
New leather gear-stick and handbrake gaiters.
R34GTT alloys in charcoal 2 pack.
225/45/17 Bridgestone Potenza S-03 tyres all round 80% tread.
R33gts25t front calipers and slotted rotors.
R32GTR cross drilled rotors on rear.
Aluminium strut-tower brace.
Koni Sport shocks with Kings low springs all round.
Nolathane adjustable castor rod bushes, adjustable camber upper arm bushes, lower control arm bushes and adjustable camber rear bushes.
Noltec urethane rear cradle mounts.
I have installed an $8K competition sound system in this car but the purchaser might not want it all at extra cost so it's negotiable.
At $8,500 the car includes an Eclipse head unit , a quality 10"subwoofer , an amp and a decent pair of splits in the front.
Phone 0266 251 365
  • 4 weeks later...
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
    • Anyone here know the answer?....missing since the w/e...
    • Google tells me that's a Japanese Rat Snake... 2m long? Man I think Australia has traumatised me to think all snakes are dangerous unless they're pythons. Also... "16 years later..." is that a record on SAU @PranK?
    • Yep, I really miss mine. I dont, however, miss it's understeer. Hard to find a genuine 'Sport' model these days. That sounds awesome! Good fun and great result!  I'd love to do a 1/4 in mine now that its reasonably healthy with the tune. I last did a run in my white GTR, I think it was a 12.3 and I can't remember the mph and I think the little E90 might be quicker.
    • FWIW, I made 372kW on a Mainline dyno, with a stock motor (bar head studs & usual bolt ons) on E85 (pretty timid timing in the mid range) and it blew up after a year of track use. Probably got like 5~6 Wakefield track days and 1x skid pan somewhere in between.
