Kumho Lap Battle Championship Results
gregor
Last month the final round of the Kumho Lap Battle championship was completed. Over the 3 rounds we visited Wakefield Park twice and Eastern Creek to wrap it all up in the company of the WRX Club and Evolution Oz. The variety of cars that attended was great, everything from lightly modded street cars through to some pretty serious machines that you might have seen at WTAC earlier in the year. The points were close and the winners were not set in stone until the last event was over and the drivers packed up for the trip home.
All of this wouldn't be possible without the entrants so thank you to those that attended even 1 event. To those who couldnt make it or were hesistant, we hope we can see you on the track next year.
The event was generously supported by Kumho Tyres through Fsport. That support means the three class winners will take home a $1000 voucher towards Kumho Motorsport Tyres. The sponsorship also saw 6 winners take home round prizes with a $500 credit towards tyres. I cant speak highly enough of John from Fsport's willingness to support club level motorsports so if you are in the market for motorsport tyres give John a call on 1300 4 KUMHO or jump on www.fsport.com.au to check for the latest specials.
The class winners are:
Open - Greg Boyle
Club - Ben Kirker
Street - Michael Hill
Congratulations to the winners!
thanks for putting these results together....and congrats on SAU members for taking out all 3 classes :cheers:
(now....all of you enter the SAU track day on 17/12....if we don't support the events I don't think the club will be able to keep running them :( )
I think the performance between the two clubs was a good match and a lot of fun. RENEW pulled second in each category so we'll keep the winners on their toes :thumbsup: We're working on our events for next year and will be in touch with the SAU NSW committee to see if there are any mutually beneficial opportunities to go racing together next year. I'm sure a greater SAU presence would be welcomed if we can get back to Eastern Creek in a multi club event.
