Carbon Fibre Care
keecho
Hi, just wondering how people care for their carbon fibre parts. my bonnet and grille are both carbon fibre. they looked milky and chalky when i purchased the car, with a little cut polish, they came up an absolute treat.
About three days later (in the garage) they have started to become milky again. what sort of polish or sealers do you guys use?
You need to determine if the parts are finished in clear 2 pak, acrylic or gelcoat...
All 3 would need to be treated differently.
If you have purchased cheap china knock off parts they will be clear gelcoat, pretty much no way of stopping the milky finish. Due to the fact the clear gelcoats used have no uv protection, you can polish them and get them clear coated but uv will still penitrate and cause the gelcoat to go milky.
Only way of stopping this is keep your car out of uv light... or paint the carbon parts the same colour as your car.
Just get used to polishing the parts to keep them looking good.
sorry for the bad news.
Not True.
You can use a sealant such as cquartz or jetseal 109 which will help greatly!
Waxes and sealants are made TO PROTECT against UV damage and other damage and carbon fibre is no different in that sense. once you polish the CF use a couple of coats of a sealant or a coat of a ceramic sealant like cquartz and you will have no issues.
Its is the same with headlights people get these "kits" that have heavy sand paper and scratch the light to much, headlights from factory have a Uv protection layer on them, all the 800 grit sandpaper does is remove all of this straight away and leave it more vulnerable to future discolouration in future UNLESS you use a sealant reguarly or a ceramic sealant as mentioned above.
Key words there are greatly help..
There is a huge range of aerospace coatings that will help too. The problem is there is no permanent solution.
I could rattle on about why but hardly anyone would understand.
Best solution would be to paint the carbon parts with a suitable product that will be stable to the TG of the resin/gelcoat used.
To give you the simple understanding if your resin or gelcoat TG is 110 degrees C and you have left the carbon finish in direct sunlight, your nice pretty clear coated carbon part will easily reach 140 degrees C
So even if you think your nice UV wax or sealant has saved you it hasn't, your part can start to soften and start to break down.
Moral of the story, if your car is a dark colour your stuffed either way. If your car is white/silver or a much lighter colour, paint your carbon parts.
Or purchase some cquartz or jetseal 109 and get use to regular maintenance.
:thumbsup:
    • I remember test driving this car at Odaiba. All the controls are very light so it's good for commuting. I don't think a 1.2L turbo would make sense in the US though, you would be constantly deep in the boost in highway cruising.
    • As the Bogan Cruise Ship has nothing wrong with it, and is perfect the way it is, I have decided to fix that issue, nothing major, just a little tidy up and upgrade some parts that don't really need to be upgraded  1. Upgrade the interchiller, basically another fancy pants modern and efficient condenser, a larger reservoir (current one only holds about 500ml) and a better pump (the current pump has a little rattle, so......while I'm in there.....) 2. Move the battery to the boot so I can use that real-estate to fit in a nice big reservoir where the battery currently is As for a new car, I'm holding off buying one for a few reasons: 1. Not enough garage space for another nice car, yes....I consider the Bogan Cruise Ship a nice car that needs a roof over its head, which leads to point 2 2. I'm buying a joint down the south coast next year, hopefully I can find a joint with a nice big double garage that I can get a car lift in, or, it has a massive shed for lots of cars, and a lift (I really really want a car lift) 3. I cannot decide what I want, a new freshness with all the mod cons, or a fairly old thing that I can play with when I'm bored (old as in steel bumper) In other news, there's a light at the end of the tunnel, and it isn't a train coming to run me over  Not that I'm counting
    • A snake slithering out of a drain in Asahiyama Zoo in Asahikawa, Hokkaido. It wasn't part of an exhibit...
    • Yes 116PS... I don't want to sound like a Toyota PR employee but it goes way better than the figures would suggest. Typical Toyota understating the performance. I'd say it at least had 130PS! 😅 Seriously though my son will be going for his licence in 2026 and it's a good manual car he can learn on without getting in too much trouble, and after that he will inherit it.
