Strange Mapping Problem
blue_vl_t
I have been in the process of upgrading the whole exhaust
removed the turbos and all the gear to replace the dump pipes,
Reassembled everything, then disconnected the battery to tack a few parts of the exhaust underneath the car with a TIG.
Now its all going, only thing changed is the exhaust(all of it), but the engine is running richer than ever before, like 13.0:1 @2000rpm in the shed, and as you back off to get closer to idle, it goes off the scales rich and obviously dies.>_<
Looked at AFM voltages, they are;
ENGINE NOT RUNNING
AFM-1 --- 0.44
AFM-2 --- 0.50
ENGINE @ 1500rpm
AFM-1 --- 1.60
AFM-2 --- 0.75
I removed the afm's cleaned them out and removed the cover from the top, checked the solder joins, they look good, they were new AFM's not long ago..
reassembled and checked again,
same results,
removed AFM's and swapped top one for bottom,
same results, and the voltages stay as is/similar.
I'll take a video and see if that helps too
any help appreciated
Edited by blue_vl_t
Intake leak will cause the car to run rich as hell, you have measured air coming in and being given fuel for but lost before it gets to the engine. I forgot one tiny vacuum hose, it was enough to make my car idle with black smoke coming from the back. Check every single silicone connector, hose, seal, everything which helps the air stay in the intake.
Edited by SargeRX8
well i had looked a few times,
but i shoved some air in the intake this time and blocked the other, and what do you know, one air leak, i'll fix that, hopefully its all the problem is.
not sure why i always think a problem is something more complicated......
fixed the intake leak, but its running just as bad, like so bad i cant keep it running unless using 1500+rpm, took it for a drive around the block, stalled like 4 times, af mixtures are just going crazy, all over the place.
it will most likely be something simple, a matter of finding it....
ecu is PFC pro, z32 afm's
o2 sensors are removed and bunged up, also turned off on the PFC.
The wiring to the rear AFM is only just long enough to reach, so wouldn't reach the front one.
Im just making up some caps for where the afm connect to the pipework, see if there is anymore leaks, pressurize the system
seems odd that the AFM voltage is so different between the 2, there is normally a bit of variation between them, but not that much.
I would be focusing on that area, melted wire, bent pin etc
Just pressurized the system with 5-10psi, looped the rocker cover breathers together, so it pressurized the whole motor, sump and all, its dead silent, no leaks, until the dipstick pops out, lol
so intake leaks, none.
I'll have to see about metering out the afm cables to the ECU, see what i come up with.
I recently had a similar problem with a Z32 that was meant to work..
I have a strange suspicion the body earth for that one is sensitive and may give a crazy effect... Mine was idling at 3.7v, yet i suspect the AFM will work fine when put into a known working case (will test tomorrow).
when using map tracer, in the shed, free revving the engine, if you hold the rpm at 2000rpm and gradually lift the throttle from the floor, the below lovely ms paint diagram shows approximately the path of the map tracer, ie which cells are being used.
Edited by blue_vl_t
blow off valves hooked up and working?
though you did pressurize the intake...
well, i haven't touched them, the car was running fine about a week ago, just removed exhaust side and reassemble with new exhaust.
as you said, pressurized intake, nothing was leaking......
Stock gtr BOV's
Edited by blue_vl_t
a prize.......
i'll take you for a spin, you live close by to Kalgoorlie, lol
I actually could not find anything wrong with the wiring, and i'm an electrician.
but the plugs on the r32/r33 model is quite crap in design, you have to push the plug in further the the bolt will pull it in.
but i recon it is was just a matter of unplug the ecu and plug it in, kinda thing. lol
I do think i will have to install another muffler, the 4" is kinda loud, i am only able to find the Magnaflow ones off the shelf, anyone know if they will do much, or someone to build one custom etc??
it should do, but my crappy superwizz turboteh bleed valve has a stripped thread, loose connection, which is probably why it was running more boost than i thought it was, i removed it, and its now running a massive 12psi, woo hoo.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Yes that sounds right. Cars currently in the shop for the engine work. Will need to remeasure .. but yes I think I must be targeting 45cm from fender.
