Vic Wasteland Thread
R31Nismoid
f*k me birds use coodnt be mor rite!
Every time I rip a singel pega in me maloo some lefty greeny f*k has a f*kin sook at me the f*kin dum dogs.
That's y I votd for abbut cos I saw this ding on channul 9 that those dum lefty f*ks rooend straya and didnt even stop the boats.
f*kn just cos I work fifo an drive a fkn haich es ve dusnt meen im a dum lefty flamin mongrel rite!
  • Like 3
What's the engine in it?
The engine description is turbo 3L so I'm assuming a variant of the VG30. I'm not really clued up with anything other than a RB or VR38 so I'm just guessing i9t's based around a VG30 lol
Lee, what about an Aristo? Luxo barge with 2J goodness :)
Say no to the toyota 2J band wagon.
And say no to selling the pulsar, you cray.
Will try convince missurs to flog off the astra and get the gloria. Get some dish, maybe get scotty to do manual conversion... Later wind up the boost.
Its a VQ30DET btw. Apparently 350Z box is an easy-ish swap. And also apparently steer well clear of the VCT 5 speed auto boxes.
Guest
