[vic] Wrecking R33 Gts-4 Complete Car!
This! @Duncan can you please edit my 2x previous posts to say B1 (just incase someone reads it and gets confused) -
Thanks, yeah the yelsha just uses a cheaper (non bosch) sensor i believe. if thats the case then the way i had the wiring the first ime should be correct. definitely going to have to consult the pin locations for the ECU. otherwise we are all just guessing!
Thank you, this was comprehensive and I consider myself an expert on the subject now. Regards, The Internet.
For the NZ wiring kit (which Yelsha copied) the black wire is + and the white is -. For me (according to my wiring notes) I have the black (+) connected to pin B1 and white (-) pin B5. Hope that helps?
Went home at lunch and swapped the white and black around and still nothing. When i get on the laptop later today or tomorrow i'll see which pin leads to what colour wire (have a wiring specialities harness) That should clear up any confusion hopefully.
