Apple Peel Come Back Cruise!
MUZT3K
Hey Guys, its been a very long time since Ive organized a Apple Peel meet reason being i lost my license for a very long time now although this one isnt going to be at the Apple Peel, its going to be around the corner at The Pines Shopping Center car park...reason being is because
this one is going to be epic and will require alot more car spots :) ...... Details are as follows
Time/Date - 18th November (Friday) 9:30pm Arrival for a 10:30-11pm Departure approx.
Meet Point - 181 Reynolds Road, Doncaster East (Outside Coles and Nando's)
Destination - Will be revealed on the night
What to Bring - Definitely a Full tank of petrol
and a CB radio Ch 12 if you have one
All cars are Welcome
Weather is hopefully by then going to be tip top so should be a huge night and lots of fun!!
also would like to mention if everyone could be on there best behavior that would be much appreciated
  • Replies 160
Glad that your back james. Finally these are back on again :)
So did you end up buying your 33gtr?
Thanks man, looking forward to seeing your new moded 34 :D
Maybe i did...:P
Maybe i did...:P
Glad that you decided to go for a gtr. Yea my car has changed over course since I saw you last. Not long before you can finally hit the roads!
damn i'll be in japan then..
oh well i'll make it to the next one.
hopefully i go to like a SJP meet at daikoku PA or something LOL surely they must have an equivalent to SAU
Lol im sure ull have lots more fun in japan then a cruise in melb
Guest
    • Thanks - to be sure will the WHC34 work?  I can’t find the other one anywhere.  Thanks
