Trumpet Sounding Air Leak When Turbo Spools Up, Can't Find Where?
I would be, however the last PS I owned was a PS1 and the last GT I played was GT1 lol. Also, how do you dads even have time to do anything? I barely have time to even sleep 7 hours a night!
