O2 Feedback
89CAL
I have O2 feedback on (pfc) and it cycles between 14.1-15.7afr when cruising, and yes i can feel the change in the "beat" of the engine similar to what Hanaldo is describing, and it clearly goes in time to when the gauge cycles from lean to rich and back
Sometimes it is worse than others but it is noticeable....never paid attention to when it is worse so i dont know if its related to operating temp but i'll monitor it now to see
Either way I just thought that it was normal due to the engine getting varying amts of fuel from being in closed loop as my O2 sensors voltage looks good and cycles as normal .........it does not do it if I turn off O2 feedback
hmmm..not connected as in not wired?
Effectively, yes. The sensor itself is still in the dump pipe, but the harness has been unplugged. When connected it gives a lot of trouble, made it impossible to tune.
Well then there is no possible way of the ecu seeing a voltage input so I cant think of any reason why the afr would cycle... just saying even if O2 feedback was indeed on and seeing erratic readings from the dud sensor when in closed loop
Sounds like you have similar symptoms but a different issue
It is not unknown for the wire that powers the heater in the O2 sensor to melt through and short the signal wire. You shoud check that loom from end to end to see if it good or bad. I can imagine it possibly feeding voltage or short to ground to the ECU if there is something wrong and seriously messing with the feedback.
    • And I hope the relay receives the trigger signal from the ECU and not the ignition power. It should prime and stop if the motor isn't running.
    • I disconnected before the fuel pump and restriction still there. Disconnected at turbosmart fpr and also after ethanol sensor and pressure dropped. No kinks in line but I found one spot above diff that I can hear the fuel flowing while running so I'm wondering if there is built up corrosion  from 10 years of sitting.  I had injectors cleaned and tested and one was dead but rest were fine. Was never an issue when I owned the car previously but I'll talk to jez about his thoughts on if they should be changed to newer tech. Thx guys at least I know the setup should work again. Pump is wired directly to relay and not using factory plug any  more
    • Nice work on the shroud/ducting.
    • Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
    • Hi everyone, Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.  Pictures of current wheels: https://imgur.com/bg1QMIu Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.  Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
