All Parts 500Awkw Responsive Package S3 33 Gtr
Well, I want to move to AN8 fittings, and the OEM has a barb. And I plan on doing these things first, as I can do them, and if the problem persists after I will then take it to a mechanic.
Definitely do just gotta pay for your own ticket and hotel rooms lol
What's wrong with the OEM filter. They do the job perfectly. As to your actual problems. Stop driving the. Take it to a mechanic. If you actually do have a fuel delivery limitation and you are putting it under load, you could be killing it.
Enjoy Japan! Need someone to carry your bags........??
I don't know the answer, but my uneducated guess is this will not work (or, not as you want it to). I would wire the SLD into VSS1, I bet that is what the limiter uses However, I also bet the ECU compares VSS1 and VSS2 and throws and error if they are different. Best suggestion I can make is wire it into VSS1 and see how you go, I guess the error will only appear above 180 when then SLD is active. If it appears at lower speeds put a switch into the SLD earth (or power supply) and only turn it on when you need to go over 180.
