Tomei Arms M7655 On Rb26
  • Replies 91
they didnt influence me to get the turbos if thats what your implying?? They didnt even know they were out, i just thought hey something new everyone has garret and hks why not be different ...
hahaha why is that??
I was there the other day, with PIGGAZ. Yavuz and us were talking about turbos for GTRs and thinking of stuff that's not just the normal bolt ons and then the tomei turbos came up.
Good on you for trying something new, I'm keen to see actual results against the typical turbo choices for GTR owners :)
Also now you mention it, that place are fantastic for trying new things, instead of the same old setups time and time again. If only there were more people out there willing to try new things.
hahahahaha yeah thats mine.. thanx for the feedback yeah i know why go down the same road thats been done a million times when everyone already knows the figures those 6 or so yr old turbos will put out...
and Don Dada they are a Journal Bearing not bb
i know journal bearings are meant to spool up marginally slower than ball bearing but hey hopefully a good tune and the cams and cam gears will help out, tomei dyno graphs show that the turbos come on around 4000-4500 rpm with the supporting mods they list so im quite happy with that
Hmmmmm....I would thought for a new release it might have used a BB cartridge to aid in spool time
Always wondered the same for the Greddy 26 bolt ons as well
I guess well just have to wait to see the results
Who makes turbs for tomei btw?....
Maybe I've missed it, but where is the graph you're referring to?
Really zoom in on the graph, 2.8l + Poncams.. I wouldnt exactly call a 2.8l stroker kit w/ cams supporting mods... and if it took that engine to spool them to there at 4000-4500rpm.. then I would be alittle worried.
Looks like would be around 200-220rwkw @ 4500rpm
With a 2.8 stroker, cams, manifolds (and who knows what else)... 24psi to make ~360-380rwkw.
I think ouch...
Comparing them to "-5s" they have a much tighter trim wheel on the compressor side (less flow), but larger exd wheel. So potentially would explain why they dont make the top end with such a small trim not getting the air in.
Simlar rear to a -5 though, just larger trim so effectively more flow, and lag. Add in journal bearing as well...
I am not of confidence having seen that PDF
I wonder why they didnt compare the R34 N1, and chose a 20yr old R33 N1 lol :D
Still be interesting to see the results none the less.
also tomei's old range of turbos were ball bearing and they discontinued them and went back to journal bearing so i dont know the logic behind this but maybe their R&D department found some progress in using it i dunno ??
It was probably cheaper, and they could make more money out of it.
the more you stroke the less revs you get but the more power so i dont see what that has to do with the spool of the turbos i could be wrong ???
Not neccesarily correct. A 2.8ltr stroker will have the same, if not more RPM capability. Depends on the head as well.
Howver 8000rpm is no problem for a 2.6 or 2.8 with a factory head.
A stroker is just shifting the power band to the right, so given you are 2.6 - move the graph to the left.
Tomei do pride themselves for being engine management specialists i dont really think they are out there to rip off people off... considering all their parts are top of the range...
and yeah i do agree with what you said about the stroke when you put it into that perspective..
guess we will find out in week when i get results fingers crossed... im sure ill be happy whatever the result only aiming for 350 awkw dont want to push the stock engine to hard and
it is only a street car
Thanx for all your input everyone
