Tomei Arms M7655 On Rb26
Just wondering if anyone has seen these turbos on the dyno or have been in a gtr with these turbos thinking of upgrading to them!!!!!
Just seems like a better option than a 5 or 6 yr old out of date turbos
  • Replies 91
I cannot give specifics, yet a friend with an R34 GTR seemed to get very mediocre results from them.. As do the evo community.
Personally I would stick to the known road with this car, RB26 has been done to death.
bought them off an american site paid 2950 included post full kit....\
um i also just bought and getting fitted
700 cc sard injectors
tomei full pump
apexi djetro ecu getting rid of air sensors coz there on there way out just a cheaper solution...
hks cam gears
tomei pon cams type B
full custom 3.5 inch exhaust
tomei bellbouth dumps
nismo fuel reg
standard internals
fair standard upgrades needed for the turbos recommended by tomei on their site...
theres a standard r34 gtr in japan with standard internals just these basic upgrades that are needed pushing 500hp with these turbos
tomei full pump
hks cam gears
nismo fuel reg
standard internals
did u have to pay any import taxes/ duty? what was the site?
I'm planning on using this kit along with vipec engine managment , 700cc sard injectors, tomei steel head gasket & walbro 255 fuesl pump!
between 400-500 awhp would be nice, not too fussed with numbers, as long as it will run a mid 12 on street tyres & i'll be happy!!!
U got ur turbos yet? mine are in the post somewhere between here & there lol
Edited by tufftruckin
should do that easily. a stock GTR with just exhaust, boost and a tune (250kw) will run low 12s on stock turbos. stagea is a bit heavier but with aftermarket turbos it should be more like low 12s or 11s.
id have to agree with GTScotT, i remember one gtr with twin tomei turbos and it looked horribly laggy (5.5k) for the 350kw or so it made!! they were done to death on evos and know all evo owners shy away from them, one sr i saw with tomei arms had a similarly laggy poor result. id stick with the tried and tested garretts imo
Not a GTR but a tracked silvia from Queensland they switched from a t518z to a equivalent size tomei and spooled later and made less power.. I hope the GTR setup's a different story for the money spent.
should have gone hks for that money
what makes hks any better?
no one on here soo far has actually seen this particular kit in action,
maybe tomei's figured out their previous kit wasn't soo flash, so they went on to developed this improved model!
will soon find out if I bought a dud once they are all fitted and tuned!
yeah i got them being fitted now just waiting on my nismo twin plate they should make 500awhp on 1.3bar thats what it listed on a japanese gtr with the m7655 fitted
tomei just revised their range these turbos came out march this year meant to be on boost buy 4- 4500 rpm so with some good cams and cam gears and a good tune hopefully see good results will soon see next week..
never know if you dont give it a go i guess
    • And I hope the relay receives the trigger signal from the ECU and not the ignition power. It should prime and stop if the motor isn't running.
    • I disconnected before the fuel pump and restriction still there. Disconnected at turbosmart fpr and also after ethanol sensor and pressure dropped. No kinks in line but I found one spot above diff that I can hear the fuel flowing while running so I'm wondering if there is built up corrosion  from 10 years of sitting.  I had injectors cleaned and tested and one was dead but rest were fine. Was never an issue when I owned the car previously but I'll talk to jez about his thoughts on if they should be changed to newer tech. Thx guys at least I know the setup should work again. Pump is wired directly to relay and not using factory plug any  more
    • Nice work on the shroud/ducting.
    • Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
    • Hi everyone, Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.  Pictures of current wheels: https://imgur.com/bg1QMIu Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.  Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
