Backfire After Installing Bov And Climate Control Light
Feels like most tend to keep it under 8000rpm for hydraulic lifters. Quick search on the net and those on Rennlist like to keep theirs under 7500rpm, Speed Talk under 8000rpm. Perhaps start to take timing out for 7250rpm and soft cut it by 8000rpm.
