Custom Imports Tv Vs Sau Vic Tv Cruise
htial
So the crew behind Custom Imports TV are heading over to Melbourne for the weekend and I thought we could show them around with a cruise up to Arthurs Seat.
We will be both filming an episode of Custom Imports TV and SAU Vic TV for each of our shows.
Meet point:- Monash Uni Clayton undercover car park (see attached image below)
Date:- Sunday 3rd of July
Time:- 9am for a 9:30 depart
See the attached map for the route we'll be taking. We'll make a stop at "Schnapper Point Drive" so that we can regroup, with a second regroup in "McCulloch Street" if needed, before the run up Arthurs Seat.
We'll take a group vote on the day as to where we have lunch. Either at Arthurs Seat or back down the hill along the beach.
Please note:- This is NOT an official SAU Vic Cruise.
Heres an episode of Custom Imports TV for you to have a look at.
So here's the list so far...
- Coming -
htial
typevu
Lil Miss 32
silva33
Mohsen
ssxRicho
vspecIInur
sirjb
shanusr33
RCHOO
Birds
Bayside Blue R34 GTV
YF34R
Miguelone
VSPECT
UNR33L
AaronNM35 + 3 or 4
W0rp3D + 1
GTEES
- Maybe -
ZILLR
WGNPWR
GTTR34
R31Nismoid
KamikazeNinja34
jesskahhh
jezza boii
R32_GODZILLA
Charles89
ClutchBurndout-:(
scarface_au
BLAKE AuST
SAU Vic TV Cruise - Arthurs SeatP2.pdf
  • Replies 191
should be in...depends if i can get work off for this
sounds great would love to attend...but flights are booked for qld that morning
lol....planning to go to qld on monday with family our self...funny if we bump into eachother..still need to book flights n accomodation...lol..looks like its going to be last minute booking..lol...
Guest
    • Vanos solenoid problems and basically all sensors die an early death
    • Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
    • from my limited BMW experience: - they burn oil WTF (B48 FTW 170kW engine) - dump oil every 5,000km and you'll be ok.. until it drops a bearing and rebuild time. replace engine with B58
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
