Questions From A V35 Rookie
Hi Everyone,
I am looking at the 2001 Skyline V35 250GT and 300GT 4 door sedans. I like Nissans, I love the look of the car, seems to have a good engine and I need the size for the kids. It ticks all the boxes for me. I just can't seem to get the info on it that is readily available like the locally made cars.
I want some feedback please if I could as I know nothing about the car cause it's a Japanese import. I've never bought an import before.
1. I have heard that many of the mechanical parts are similar/identical to those used in the Maxima and Murano and therefore parts are relatively cheap to source locally (I'm in Sydney) - Is this true?
2. Body panels and interior are apparently only available from Japan, hence making them more expensive? Is this true?
3. I have heard horror stories of clocks getting wound back (there are a few 2001 models out there with like 40,000km on the clock for $15k and under). Can this be easily done on this car? Is it likely to happen?
4. Buying a Japanese car, how can I be sure that the car isn't hammered in bumper to bumper "stop/start" traffic every day?
5. In general, is the car reliable? Does it have a reputation for engine faults after certain amount of km's are clocked up?
6. Transmission? Will it play up after a certain amount of km's?
7. Any other tips to think about?
Thanks everyone
Parts are easy to get if your talking service parts. If your looking for body parts then they cost a little more and take awhile to come from Japan.
Yes clocks get wound back alot. Most Dealers do this themselfs. It's very easy. Best to import yourself if you have the time and it's alot cheaper. Or buy private from someone who imported themself.
You can always get the car checked out by RAC or similar.
The car is reliable as any other car. Looka after it and it will look after you.
Transmission, If it's an 8speed triptonic then at 100,000km then it needs a large costly oil change.
The Best tip is test drive a few even if you can't aford some of them. The you know if there is anything standing out that isn't right. Look at wear and tear of seat belts, stearing wheel, gear stick, seats and foot peddles. 40000km is like new.
PS 2001 with 40,000km...... hmmmmmm only 4000 a year.
Hi Everyone,
see inserted comments :)
if you are talking service parts - yes.
correct. though you may get lucky and find some bits of it ex MLB.
plenty of the wound back. its only 4 bolts , 3 plugs and its off and swapped out. importers do it , yards do it individuals do it. if there are any japanese service stickers in the doors sills or on the side of the dash have a look at those. clocking seems to be more common on the 2 door ones.
same as every other car. if its taken care of then it will last a while.
usually. they suffer cam sensor problems , various electrical faults and the like. windows and locks are the worst two unless its been fiddled with then its a pain in the ass to work with. ( I fix these cars for a living.) if it has CVT-8 any where on it - AVOID IT. they are great when they work and will write teh car off when they break.
see 5.
have a read of the FAQ. might help you.
    • Hi! Is it possible to use and swap the RB25DET/RB25Neo manual gerbox on to my RB20DE Neo engine with an automatic transmission?
    • my current daily - BiTurbo Diesel SQ5 8R with a remap and some light cosmetic mods. Which is sitting in front of my old daily that hasn’t been driven in 7 years now, home to numerous redbacks no doubt. MK4 Golf GTI with a boser hood extension, air ride airbag suspension, factory RHD Xenon’s from the Japanese R32 and stubby electric mirrors (also from Japan) sitting on custom made 18x10” Work Meisters for the golf’s bolt pattern and offset. one day I’ll revive it as a project, pull the engine out, put some forged bits in, chuck a big turbo on it and tune it to somewhere around 250kw and call it a barn find to make millions off YouTube views. Till then, it is a good breeding home for redbacks and the boot is good for storing my Christmas tree for 11 months of the year.
    • Thanks for jumping in guys, suggested @Sbluatx post here for help. Was hoping one of the guys with a RWD stages could confirm if the tank was the same as the AWD one
    • I got another MAF and installed it. Idle misfire was still present. Finally got the tank low enough to refuel and did so. Did a short drive to warm the car up and no issues, pretty short drive. Going to attempt soon to take a longer drive to see. I don't think the MAF fixed it if anything, definitely thinking it was fuel related. As soon as I put fresh fuel in the car felt so much better. But, still need a longer test drive to verify. I'll report back once done.  I'm definitely going to be getting monitoring and tuning parts soon as my next upgrade (decided on the link after talking with my tuner), just been real tight with just purchasing the car and sudden onset of issues. I've also ordered a new exhaust stud kit and gasket to fix that obvious problem. Once it's back up to par I'll start with the goodies
    • Meant it’s 2WD. And my tank is cracked.
