R33 Gtst Complete Upgraded Front Brake Package
PM-R33
Hey guys
Have for sale my R33 GTST front brake setup due to a brake upgrade.
The kits consits of:
Nissan 4 Piston GTST Calipers Painted Black
RDA Slotted/Dimpled Gold Passivated & Zinc Coated Rotors
EBC Red Stuff Brake Pads
Hel ADR Approved Braided Brake Lines
Perfect upgrade for a Skyline GTST/GTS or a Silvia and basically the best you can get out of the factory calipers. The calipers are a lot lighter than Silvia calipers and obviously the rotors are larger than Silvia rotors.
The rotors and pads have plenty of meat on them, were purchased brand new a few of years ago. Car doesn't do that many kms so still very good.
Would prefer pickup in Townsville due to weight however freight could be organised.
Would like $500 ONO.
Phil
