Hks, Trust, Turbosmart, Precision Turbo
I'm back from overseas and I'm cleaning out the shed to fund my TD06 requirments.
Precision Turbo- Billet comp wheel, PT5557 570hp turbo. Less than 1500km old, some dyno runs and a couple of gymkhana events. This turbo is currently on my rb25/R32 (some may have seen the set up in action at the DEC gymkhana event last year). The car is currntly making 250rwkw with more in it. Dyno sheet and or ride can be arranged.
Turbo- $1000
Wastegate- $350
Stock manifold wastegate adapter- $250
Package- $1400
Nismo 260km/h dash for R32 GTR- 87k kms on the clock. As far as I know it suits early 32's. $250
Generic JJR oil cooler kit- Used condition, but everything is there. $200
Twin td05 kit to suit rb26. Used condition. Manifolds are very well made (japanese) with no cracks. Turbos are in ok condition, minimal shaft play and thrust play. Comes with dump pipes. $1000
Genuine N1 oil pump- new in box. $350
Turbosmart FPR-800 fuel pressure regulator- used but in good condition, includes some fittings. $200
Turbosmart bleed valve- used. cheap. $50
Turbosmart V port blow off valve- used. also cheap. $75
VH45/Q45 V8 90mm throttle body- used but good condition. has no tps but your rb20/25 s1 will bolt straight on. also has coolant temp idle adjustment (cool!). $250
RB Flywheel- used, no cracks. $100
SPEC clutch plate- used. $50
HKS GT 2835- needs a rebuild and the housings are good. $350
RB26 conrods- straight and undamaged. $120
HKS cast low mount exhaust manifold- is don is good, but has a crack along the divider inside... I have had a quote for repair (correctly) for $150 by a cast material welding specialist. Rare item $450
HKS square base wastegate- has bolts, valve seat and gasket. $350
Trust rb26 pod adapters- good condition, needs polishing. $100
Intercooler- generic JJR. $100
Package deals can be made, all shipping will be additional (don't ask for shipping prices unless your very keen) and all parts can be inspected/picked up from south Tasmania- Hobart Area.
PM me here or call/sms
Justin
Cooler sold to me :cheers:
If you are interested in selling that intake pipe in your first Rb25 picture, let me know. Or tell me, is it custom made or bought? If so how much and where from? Maybe you can PM me a pic of your intake system(infront of the turbo)?
Edited by SargeRX8
