Happy Laps At Lakeside. Sunday May 22
FineLine
Its on again folks, date as above.
Same meetup place. Hypermarket car park at Aspley
Departure from there will be at 4.15 sharp. if you're not there by then you are left to your own devices.
On track cruising from 5 to 5.30 evening meal to follow.
Add you name here
Updtaed list
1. Fineline
2. Benno
3. Beelzebub 89
4. RBNRG
5. sneakey pete
6. SPR34
7. v8skylineman Plus beck.
8. bunta plus Impact blue
9. traditimeour (maybe)
10. ezy34
11. 2cents
12. alloskylineallo
13. grae35
14. Joe
14. Dan B
15. Shop pi
16. skylinestyle101
17. si (maybe)
18. R33eddy (maybe)
19. Milan
20. Smity42
21. One of the owners of the pub who drives an E63 amg
22. Spilmer
23. IanB
24. grimi
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
