Most Power With A Return Flow Intercooler And Std Piping?
Hey all. Had a bit of a scare today with my R34 GTT when i flicked on the tail/parker lights, and some wiring started going up in smoke under the dash. The fuse didnt blow, it just melted the casing of the fuse so must have been a crap fuse? Previous owner did alot of wiring, some of which is quite sub par and the fuse that melted was definitely newer than the other ones that were in the fuse box, but didnt seem that he touched the wires that mainly got melted. Anyway may need a small section of a new loom, is there lots of similarities between the turbo and non turbo looms especially for under the dash stuff? The wired that got friend go into a 6 pin relay under the dash. The non turbo ones are less than half the price here from a wrecker and all i would need it the section that got fried and any other wires that are affected. Thanks in advance
