R33 Idle Issues
Hey guys I'm having an issue with my cars idle and I'm posting a picture of my Powerfc IDLE/REV screen and wanting you guys to post the same if you have similar setup so I can see if everything is setup right.
RB251PRO Apexi PFC r33
Rb25det s2
z32 air flow meter
Catch can + breather
3.5" cat back
Rb25det s2
z32 air flow meter
3.5" cat back
Those ac recover values are certainly not correct..ie. the two values that are 9999rpm right now
They are suppose to be around 1000rpm....Maybe some one with a 25det pfc would be able to give you the default values although i think this would not affect idle directly.
Did they perform the idle learn proceedure on the pfc at installation?
I would set as:
1100
1150
900
950
The 2nd and 4th values are for the A/C.. the 1st and 2nd are for the fuel recovery points. I found out if you're not using a BOV lower values tend to be better.
If you're having idle issues, I suggest hooking up a wideband and seeing that your A/F are.
fuel cut recovery RPM
one is elec load on and elec load off
the first FC cut is pro launch control RPM though
again
whats the problem with your idle
what happens
what doesnt happen that you are expecting
when did it change or last work
is it set to the right afm?
Have you had a tuner look at it?
Have you search for 'idle hunting' issue on SAU?
Have you checked & cleaned AAC valve?
is the AFM working? is it plugged in?
and of course everyones favourite do you have an atmo bov? not that mine causes me any problems...
Could be lots of things, good place to start is to maybe search for idle hunting on SAU forums
before doing any of that who installed the powerfc and did you follow the install instructions
there is a set 30 min idle procedure you must run
if you dont do it properly or skip it
the car will basically instant stall or stall when revved
