Fs - Skyline V35 Sedan Bodykit
For sale is a bodykit imported from the USA for a Nissan Skyline V35 Sedan.
Items - Kurookie front bar and Nisrookie sideskirts
Price - $1400 for the set. Currently I do not wish to separate them.
Condition of items - New, primed and ready to be painted.
Items are located in Perth WA
PM me or contact me on 0430378505 if your interested.
Cheers, Jason
Cheers, Jason
Very nice looking body kit you got there for sale, mate. :thumbsup:
I've got a couple of friends with V35 sedans. I will ask them around and let you know if they are interested. :)
Edited by Victor.T
thanks for the comments guys. Ni5mo is right, it is for the series 1 v35 sedans before they got a facelift. It does have space for side indicators though. I took that picture of the g35 site, and he must of moulded the side incators area.
Edited by channy1210
  • 6 months later...
