Datsun C210 Skyline
Selling my Datto, need something I can bash around, this isn't the car for that.
Subject: NSW,1978 Datsun C210 coupe, $5000, obo
For sale: 1978 Datsun skyline (240k) C210 hard top
Item Condition: Fairly tidy for a 30 odd year old car, original black/beige interior, few cracks in dash, couple small rips and tears, new carpet/floor mats, tach/clock not working, stock L24 six cylinder, headers and 2.25" stainless exhaust with resonator/twin pipes, better intake manifold with stock carby, serviced-points/plugs/leads/filters/oils/coolant/hoses, 5spd, new clutch kit, back yard respray less then 12 months ago not perfect but looks good, green base, green/gold colour flip pearl, heaps of clear, most trims in good nic (few cracks and dings)
Price and price conditions: $5000, obo
Extra Info: Has a locked r160 at the moment, will come with original r180 (its a good diff) just put silkroad RM/A8 rear coilovers from an r32 gts-t in with adaptors so no extra holes drilled, replaced swaybar bushes front/rear, also have s12w Hilux callipers that could go with it been media blasted need to be kitted. also have a half made supercharger kit suit sc12 blower and a 310 Holly carb wouldn't need much to finish my sc12 is f@#ked but more then welcome to it, will have bonnet/guard trims early in the new year just need to pick them up.
**WILL COME WITH THE 5 FACTORY ALLOYS/WITH CAPS AS THE CHEVIOTS ARE NOT MINE**
Factory alloys have been paint striped and could use a polish, may be able to media blast them to clean them up. tyres will be swapped from cheviots, good tread.
Contact Details: PM, [email protected], or call Dan on 0459 997 556
Delivery & Conditions of Delivery: pickup, courier interstate or overseas at your cost and if you organise, what ever floats your boat.
Pictures:
just ask if you need more :thumbsup:
Cheers,
Dan
  • 3 months later...
  • 3 years later...
    • that's pretty good condition, those chips are nothing. Get a mobile repairer to sort it out. Nice wheels, I had white 17's on my GT-R once, looked nice.
    • Found a car that has kiki desing wheels on it with diffrent plates that match a 2008 model when clearly it's not white
    • Howdy friends, So this evening I had a need to remove the rear compressor turbo pipe (long story, but I'm replacing it due to a bolt snapping off in the pipe and managing to then snap an extraction bit in the broken bolt, fun times -_-). The rear bolt is a bit of a bastard and very little room to get good leverage. I was able to get a 12 mm socket onto the bolt head, but none of my ratchets were able to fit, so I put together a "stubby" socket wrench to get it out and it worked surprisingly well 🙂. In the past I've "made" tools by cutting down spanners and bending them with a torch etc, but this 3D printed wrench was way less effort. I'll be keeping this one in my "special tool draw" from now on for sure ^_^b https://www.printables.com/model/868973-half-inch-stubby-socket-wrench
    • It looks even better in Person
    • It's good, but not as good as some people make it out to be on social media. Yes, you can feel the torque come in earlier, yes, it does make the car feel more lively below 4000rpm, and yes, it does feel more responsive, but it's not this 'unicorn' mod.  Everyday driving? Below 100km/h on Australian roads, it's worth it. At 110km in 6th gear mine will sit on about 2860rpm. Doing a Motorkhana or a small circuit? Yes, it's worth it. Doing Texas style speed runs? Prob not. Do you use the gears more? Yes and No. Doing 60/70km on most roads, I'm using the gears just like any other Getrag. 80km and above, you use 5th and 6th more often. Absolutely no issues driving with the 33 A-LSD. Didn't change the front diff, only changed the C&P wheel. Some people say to upgrade to a Quaife etc, but i've had no issue with torque steer or having it wander all over the road. The one thing that no-one really addresses is the issue of the Speedo being out. It's either use a speedo corrector, find a 33 gearbox speed sensor, or use an aftermarket display with GPS speedo.
